Network Encryption
ciscolqbly
Frequent Visitor
Frequent Visitor
I would like to encrypt traffic between two switches.
what is the best option (Cisco and none cisco)?
device/software/hardware
If you want to achieve line-rate performance, it should be implemented in the switches. For the VPN, you could use any open-source firewall that supports IPSec. If unsure, take a look at pfsSense.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Look for devices that support MACsec (802.1AE). This is a standard, but be aware that there are proprietary implementations. On the Cisco side, this function is implemented in the 3650/3850 and higher line of switches. From the older generation of switches, the 3750-X also implements MACsec.
Another solution is to place firewalls/routers on both sides and implement IPsec VPNs.
any freeware traffic Encryption?
