Network equipment layout
Tbaror123
Community Member
Hello All,
First i am not a Cisco expert but i have been asked to advice between two layout equipment as follows.
First layout would be
2x Nexus 5596UP >> 4 X Cisco 3750x stacked
Second layout would be
2xNexus 5596UP >> 4 X Nexus 2248
i would like to have advice of pros and cons using either Cisco 3750x as edge switch and same for Nexus 2248
sean_evershed
Level 11
Level 11
The 2248's are designed to be a fabric extension to the 5596 parent switch. This means that you can take advanatage of the high end Nexus operating system features such as vPC and in-service upgrades. These are imporant features for data centres. They are typically deployed as top of rack switches for server farms.
The disadvantage of the 2248's are is if the 5596 fails then the 2248 also fails.
The 3750X are not an extension of the 5596, rather they are a stand-alone switch. Therefore they can't leverage the Nexus feature set.
The advantage of the 3750 are
- If the 5596 fails then the 3750 will continue to operate.
- It also supports Layer 3 out of the box. To support Layer 3 on the 5596 and the 2248 you need the Layer 3 daughter board installed.
Don't forget to rate posts that are helpful.
sean_evershed
Level 11
Level 11
