network health check and configuration advise
abakhashwin
we are looking for a tool for a cisco routers health check and review the configuration and advise the update ,please advise for any tools
fb_webuser
Level 6
Level 6
Cisco Network Assistant (Cisco proprietary) but it lacks reporting feature...its more likely real time monitoring tool
Alternatively you can go for Solarwinds NPM and Opmanager
Posted by WebUser Musab Kiani from Cisco Support Community App
what i need is tools /softeware to check the configuration of the router and advise if some thing need to be updated
hi abakhashwin,
are you familiar with Cisco Configuration Professional? (http://www.cisco.com/en/US/prod/collateral/routers/ps9422/data_sheet_c78_462210.html)
or perhaps you can check Cisco Security Management Suite, which consist of CS-MARS (http://www.cisco.com/en/US/products/ps6241/index.html) and Cisco Security Manager (http://www.cisco.com/en/US/products/ps6498/index.html) as the main components
regards,
Ganesh Hariharan
Lan Management Solutions available and can handle a high number of devices and does various items including configuration management, software management, topology map, visual view of devices and more:
http://www.cisco.com/en/US/partner/products/sw/cscowork/ps2425/index.html
For less devices you can look at SNMS:
http://www.cisco.com/en/US/partner/products/sw/cscowork/ps2408/index.html
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/white_paper_c11-542881.html#wp9000091
Hope to Help !!
Ganeshh Iyer
