Network issue
nareshkumar4ever
Community Member
I am working as an Intern at The Conference Center Niagara Falls, I got an issue with the network. I got a WC-C3750G-12S as one of the device and the GigaEth1/0/2 , 5, 6 turn amber frequently (like twice in a hour). I guess the problem is with spanning tree.\
can any one suggest me troubleshooting procedure.
Thanks in advance.
-naresh
cadet alain
1) turn on logging ------> logging on
2) enable timestamps for logging ----> service timestamp logging.
3) log to a server or to buffer --->
logging x.x.x.x
logging trap debugging
or logging buffered debugging
     logging buffered 20000
4) watch for correlation between the logs and the turning amber of port leds
Regards.
Alain.
Thank you Cadetalain... I'll try that.cadetalain
Cadetalain,
I followed your instructions and these are the logs which I obtained, I am unble to figure the exact problem with the ports. do you have any idea what could be the problem?
10.10.40.3    03/09/11 12:36:25    03/09/11 12:36:25        local 7    Notice    074600        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to up"
10.10.40.3    03/09/11 12:36:22    03/09/11 12:36:22        local 7    Notice    074599        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to down"
10.10.40.3    03/09/11 12:32:31    03/09/11 12:32:31        local 7    Notice    074598        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 12:32:28    03/09/11 12:32:28        local 7    Notice    074597        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 12:30:09    03/09/11 12:30:09        local 7    Notice    074596        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to up"
10.10.40.3    03/09/11 12:30:06    03/09/11 12:30:06        local 7    Notice    074595        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to down"
10.10.40.3    03/09/11 12:28:26    03/09/11 12:28:26        local 7    Notice    074594        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 12:28:23    03/09/11 12:28:23        local 7    Notice    074593        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 12:09:19    03/09/11 12:09:19        local 7    Notice    074590        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 12:09:16    03/09/11 12:09:16        local 7    Notice    074589        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 11:59:00    03/09/11 11:59:00        local 7    Notice    074588        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 11:58:57    03/09/11 11:58:57        local 7    Notice    074587        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 11:51:40    03/09/11 11:51:40        local 7    Notice    074586        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 11:51:37    03/09/11 11:51:37        local 7    Notice    074585        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 11:51:31    03/09/11 11:51:31        local 7    Notice    074584        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to up"
10.10.40.3    03/09/11 11:51:28    03/09/11 11:51:28        local 7    Notice    074583        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to down"
10.10.40.3    03/09/11 11:51:02    03/09/11 11:51:02        local 7    Notice    074582        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 11:50:59    03/09/11 11:50:59        local 7    Notice    074581        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 11:50:32    03/09/11 11:50:32        local 7    Notice    074580        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to up"
10.10.40.3    03/09/11 11:50:29    03/09/11 11:50:29        local 7    Notice    074579        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to down"
10.10.40.3    03/09/11 11:49:39    03/09/11 11:49:39        local 7    Notice    074578        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 11:49:36    03/09/11 11:49:36        local 7    Notice    074577        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 11:45:11    03/09/11 11:45:11        local 7    Notice    074576        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 11:45:08    03/09/11 11:45:08        local 7    Notice    074575        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 11:34:16    03/09/11 11:34:16        local 7    Notice    074574        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 11:34:13    03/09/11 11:34:13        local 7    Notice    074573        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 11:32:44    03/09/11 11:32:44        local 7    Notice    074572        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 11:32:41    03/09/11 11:32:41        local 7    Notice    074571        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 11:22:25    03/09/11 11:22:25        local 7    Notice    074570        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 11:22:22    03/09/11 11:22:22        local 7    Notice    074569        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 11:17:00    03/09/11 11:17:00        local 7    Notice    074568        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to up"
10.10.40.3    03/09/11 11:16:57    03/09/11 11:16:57        local 7    Notice    074567        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to down"
10.10.40.3    03/09/11 11:13:55    03/09/11 11:13:55        local 7    Notice    074566        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 11:13:52    03/09/11 11:13:52        local 7    Notice    074565        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 11:11:05    03/09/11 11:11:05        local 7    Notice    074564        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to up"
10.10.40.3    03/09/11 11:11:02    03/09/11 11:11:02        local 7    Notice    074563        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/2, changed state to down"
10.10.40.3    03/09/11 11:04:05    03/09/11 11:04:05        local 7    Notice    074562        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 11:04:01    03/09/11 11:04:01        local 7    Notice    074561        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 11:02:00    03/09/11 11:02:00        local 7    Notice    074560        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 11:01:56    03/09/11 11:01:56        local 7    Notice    074559        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 11:01:17    03/09/11 11:01:17        local 7    Notice    074558        "17w6d: %SYS-5-CONFIG_I: Configured from console by console"
10.10.40.3    03/09/11 10:53:28    03/09/11 10:53:28        local 7    Notice    074557        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 10:53:25    03/09/11 10:53:25        local 7    Notice    074556        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 10:47:04    03/09/11 10:47:04        local 7    Notice    074555        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 10:47:01    03/09/11 10:47:01        local 7    Notice    074554        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 10:35:27    03/09/11 10:35:27        local 7    Notice    074549        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 10:35:24    03/09/11 10:35:24        local 7    Notice    074548        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 10:33:23    03/09/11 10:33:23        local 7    Notice    074547        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 10:33:20    03/09/11 10:33:20        local 7    Notice    074546        "17w6d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 10:32:47    03/09/11 10:32:47        local 7    Notice    074545        "17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 10:32:44    03/09/11 10:32:44        local 7    Notice    074544        "17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 10:29:54    03/09/11 10:29:54        local 7    Notice    074543        "17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to up"
10.10.40.3    03/09/11 10:29:51    03/09/11 10:29:51        local 7    Notice    074542        "17w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/5, changed state to down"
10.10.40.3    03/09/11 10:29:44    03/09/11 10:29:44        local 7    Notice    074541        "17w5d: %SYS-5-CONFIG_I: Configured from console by console"
