Network Solution
kumaravinash
Visitor
I am going to implement one network infra where 2 no's nexus 3524 switches is using as core switch and 4 C2960 access switch connected with core switches. I have two ISP link in my network connected on router and router connected with our nexus switch.
I want to use both the link and looking for a solution that one VLAN traffic goes from one link and second from another.
My network diagram is :
nazimkha
Routing based on VLAN may not be a good design. i.e layer 2 termination from the Nexus to the Router.
If the connection between the Nexus and the router is L3 you may be able to tweak the routing using prefix-lists, route-maps, etc
Hi kumaravinash,
You can easily achieve this by using HSRP or GLBP.
