Network Speed
dbriffa@gmail.com
Community Member
If you've got a 1 gigabit switch with individual gigabit ports, 1 gigabit network cards, Cat 6 and Cat 7 cables over a very short distance (10m) but the router is a 1 megabit; are you bound to the speed of the megabit or gigabit? DHCP is being used.
Reza Sharifi
If the data has to go through the 1 megabit pipe then you are limited to 1 megabit.
