Network Upgradation
r.kukreja
Level 5
Level 5
we are having 4510R+E , now with 1 gigabit uplink want to go for 10 gigabit uplink
what are the benfits of 10/100/1000 with 10g uplink against if we buy 10/100 with 1g uplink. kindly suggest some models of both
regards
rajat
5 Replies 5
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Whenever you increase edge bandwidth, i.e. moving from 10/100 to 10/100/1000, it should take less time to transfer the same amount of data.  Having an uplink faster than the edge allows multiple concurrent edge transfers without congestion; it also reduces serialization latency.  However, if you don't commonly have multiple edge transfers, and serialization latency isn't adverse, you might find you don't benefit as much from increasing uplink 10x, especially if Etherchanneling is an option.  Also remember, increasing edge bandwidth 10x doesn't mean there's also a 10x increase in actual data transferred. In other words, as you increase edge bandwidth from 10 to 100 to 1000, you might find you don't need to increase uplink bandwidth in the same ratios.
Datasheet for its line cards can be found here: http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea_ps4324_Products_Data_Sheet.html
Overview of 4500 series 10 gig can be found here: http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/prod_brochure0900aecd802a56f3.pdf
Thanks a lot joseph,
if we move 1 gigabit uplinkhaving backplane 6gbps  to 10gigabit uplink but backplane is 48gbps how much performance speed will improve do you have any mathematical calculation.please suggest best 10g uplink switch without poe
regards
rajat
I presume you haven't heard of the 6500E and the Sup2T with 80 Gbps backplane and ability to support 40 Gbps.
Hi leolaohoo
thanks for your kind knowledge sharing but i have limitation that ihave hardware platform of 4510R+E instead of 6500E. so, waiting your reply as my above query.
regards
rajat
Disclaimer
Posting
You might be mixing "apples and oranges".  The 6 Gbps backplane is the limitation bandwidth to original 4500 card slots, not a limitation to uplinks on supervisor itself.  (For example, the SupV-10ge can drive both 10 gig links at wire-speed.)  The 48 Gbps backplane is available with the Sup7 and 48 Mbps line cards.
Assuming most your bandwidth usage will be "north-south" (i.e. to/from uplink), the uplink(s) become the principle bottleneck.  For such, the SupV-10ge might be as effective as a Sup6 or Sup7 variant.  The Sup6/7 variants are better if you need more bandwidth between line cards or need 10 or 20 gig to supervisor to/from and individual line card.
