network upgrade
SHA1990
Community Member
we are upgrading our network, so we're going  from WS-C6513-E to Cisco Catalyst C9407R Chassis, but the the issue with the Cisco Catalyst C9407R Chassis it doesn't have a 40G line card, so is there a 40G module that supports the Cisco Catalyst C9407R Chassis ?
Thank you in advance.
7 Replies 7
Mark Malone
Not currently , the 9500 does and 100gb ports
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9400-series-switches/datasheet-c78-739054.html
C9500
Product highlights
     Cisco Unified Access Data Plane (UADP) Application-Specific Integrated Circuit (ASIC) ready for next-generation technologies with its programmable pipeline, microengine capabilities, and template-based, configurable allocation of Layer 2 and Layer 3 forwarding, Access Control Lists (ACLs), and Quality-of-Service (QoS) entries
     Intel® 2.4-GHz x86 CPU with up to 120 GB of USB 3.0 or up to 960 GB of SATA SSD storage for container-based application hosting
     Up to 6.4-Tbps switching capacity with up to 2 Bpps of forwarding performance
     Up to 32 nonblocking 100 Gigabit Ethernet QSFP28 ports
     Up to 32 nonblocking 40 Gigabit Ethernet QSFP+ ports
     Up to 48 nonblocking 25 Gigabit Ethernet SFP28 ports
     Up to 48 nonblocking 10 Gigabit Ethernet SFP+ ports
     Platinum-rated AC/DC power supplies
Georg Pauwen
according to the doc below, the Catalyst 9400 Supervisor Engine-1 and Supervisor Engine-1XL uplink options include two 40G ports (check Table 6 and Table 7):
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9400-series-switches/datasheet-c78-739055.html
Oh good spot i was looking for 40GB linecards
yes, but besides the supervisor engine-1 and the supervisor engine-1xl, are there any ?
no, I don't think there are any line cards with 40G ports...
the list i posted shows no specific cards available yet but the 95 does
HI,
Please have a look!
Cisco Catalyst 9400 Supervisor Engine-1XL-Y uplink options
Supervisor configuration
Uplink ports options
Single supervisor
8x 10 Gigabit Ethernet ports are active (ports 1 to 😎 (2x 40 Gigabit Ethernet ports are disabled [ports 9 to 10])
2x 40 Gigabit Ethernet ports are active (ports 9 to 10) (8x 10 Gigabit Ethernet ports are disabled [ports 1 to 8])
4x 10 Gigabit Ethernet and 1x 40 Gigabit Ethernet ports are active (the other 4x 10 Gigabit Ethernet 1x 40 Gigabit Ethernet ports are disabled)
2x 25 Gigabit Ethernet ports are active (ports 1 and 5) (6 x 10 Gigabit Ethernet ports are disabled (ports 2-4 and 6-8) and 2 x 40G [ports 9 to 10])
4x 10 Gigabit Ethernet and 1 x 25 Gigabit Ethernet ports are active (the remaining ports are disabled)
1x 25 Gigabit Ethernet and 1x 40 Gigabit Ethernet ports are active (the remaining ports are disabled)
*** Please rate all helpful responses and mark solutions***
