New to Cisco 3750G switch, need some help
mnaglie11
I setup a new Cisco 3750G switch; on port one I have my ASA5520, on port two I have a server and on port three another server. I can ping the gateway on port one but cannot ping each server only server outside the gateway on port one. The switch is complex and I have the CNA software now but not sure what I need to configure to get the two servers to communicate with each other. All ports vlan.
spremkumar
Level 9
Level 9
hi
do revert whether the ports where you are connecting the servers are in the same vlan ?
also whts the ip address,default G/Ws set on the server ?
if possible do post out the config of the switch.
regds
Figured it out today; the switch was fine. The asa5520 connected to it had the Proxy arp set on the internal zones so arps were being fielded by the asa5520 gateway. Thanks for your reply!
