NewB DHCP question
himanshurgu
Hello there,
I am new here, so hello to all.
I am a networking student, and trying to set up DHCP server on Cisco Routers and ISRs.
The problem I will mention below relates to Cisco 867VAE. I have attached the config file for ready reference.
The problem: The DHCP pool does not hand out IP addresses. I have tried it by the book, line by line with no luck.
Router#sh ip dhcp pool
Pool HomeNetwork :
 Utilization mark (high/low)    : 100 / 0
 Subnet size (first/next)       : 0 / 0
 Total addresses                : 254
 Leased addresses               : 0
 Pending event                  : none
 1 subnet is currently in the pool :
 Current index        IP address range                    Leased addresses
 192.168.1.1          192.168.1.1      - 192.168.1.254     0
Router#sh vlans
Router#sh vlans
No Virtual LANs configured.
Please advice.
I am sure, it is my mistake. as I am having same problem with another ISR 892w. Config file follows:
Thank you all,
Himanshu
System Bootstrap, Version 15.1(4r)M2, RELEASE SOFTWARE (fc1)
Copyright (c) 2011 by cisco Systems, Inc.
C860VAE advanced k9 platform with 256 MB of main memory
Booting flash:/c860vae-advsecurityk9-mz.155-1.T.bin
        ################################################################## [OK]
              Restricted Rights Legend
to
export@cisco.com.
Cisco 867VAE-K9 (revision 0.3) with 234496K/26624K bytes of memory.
Processor board ID GMK17310487
1 DSL controller
1 Ethernet interface
4 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
255K bytes of non-volatile configuration memory.
57344K bytes system flash allocated
SETUP: new interface NVI0 placed in "shutdown" state
Press RETURN to get started!
*Mar  7 16:34:53.315: PIM: BFD initialization failed
*Mar  7 16:34:55.523: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State change        d to: Initialized
*Mar  7 16:34:55.527: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State change        d to: Enabled
*Mar  7 16:35:03.379: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0        , changed state to up
*Mar  7 16:35:03.383: %LINK-3-UPDOWN: Interface Ethernet0, changed state to down
*Mar  7 16:35:03.383: %LINK-3-UPDOWN: Interface ATM0, changed state to down
*Mar  7 16:35:03.383: %LINK-3-UPDOWN: Interface GigabitEthernet1, changed state        to down
*Mar  7 16:35:03.383: %LINEPROTO-5-UPDOWN: Line protocol on Interface Onboard VP        N, changed state to up
*Mar  7 16:35:04.007: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, cha        nged state to down
*Mar  7 16:35:04.999: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0,        changed state to down
*Mar  7 16:35:04.999: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, chan        ged state to down
*Mar  7 16:35:04.999: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth        ernet1, changed state to down
*Mar  7 16:35:09.271: %CONTROLLER-5-UPDOWN: Controller VDSL 0, changed state to        administratively down
*Mar  7 16:35:09.819: %LINK-5-CHANGED: Interface GigabitEthernet1, changed state        to administratively down
*Mar  7 16:35:09.967: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  7 16:35:10.947: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, chan        ged state to down
*Mar  7 16:35:11.343: %LINK-5-CHANGED: Interface ATM0, changed state to administ        ratively down
*Mar  7 16:35:11.343: %LINK-5-CHANGED: Interface Ethernet0, changed state to adm        inistratively down
*Mar  7 16:35:12.119: %LINK-5-CHANGED: Interface NVI0, changed state to administ        ratively down
*Mar  7 16:35:12.119: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to        down
*Mar  7 16:35:12.119: %LINK-3-UPDOWN: Interface FastEthernet1, changed state to        down
*Mar  7 16:35:12.119: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to        down
*Mar  7 16:35:12.119: %LINK-3-UPDOWN: Interface FastEthernet3, changed state to        down
*Mar  7 16:35:12.119: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state        to down
*Mar  7 16:35:13.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern        et0, changed state to down
*Mar  7 16:35:13.155: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern        et1, changed state to down
*Mar  7 16:35:13.155: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern        et2, changed state to down
*Mar  7 16:35:13.155: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern        et3, changed state to down
*Mar  7 16:35:13.155: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth        ernet0, changed state to down
*Mar  7 16:35:15.151: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C860 Software (C860VAE-ADVSECURITYK9-M), Version 15.5(1)T, R        ELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 19-Nov-14 01:39 by prod_rel_team
*Mar  7 16:35:15.663: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Mar  7 16:35:15.663: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Ac        cess1, changed state to up
*Mar  7 16:35:15.663: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state t        o up
Router>en
Router#sh ru
Building configuration...
Current configuration : 1889 bytes
version 15.5
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
wan mode ethernet
no ip subnet-zero
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.1.1 255.255.255.0
ip dhcp excluded-address 192.168.1.2
ip dhcp excluded-address 192.168.1.3
ip dhcp excluded-address 192.168.1.5
ip dhcp pool HomeNetwork
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 dns-server 8.8.8.8
ip cef
no ipv6 cef
controller VDSL 0
 shutdown
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
 pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Ethernet0
 no ip address
 shutdown
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 no ip address
 shutdown
 duplex auto
 speed auto
interface Vlan1
 no ip address
interface Dialer1
 ip address negotiated
 ip nat outside
 ip virtual-reassembly in
 encapsulation ppp
 dialer pool 1
 ppp chap hostname =============@skydsl
 ppp chap password 0=========
 ppp pap sent-username c========skydsl password -------------
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-list 1 protocol ip permit
access-list 1 permit 192.168.1.0 0.0.0.255
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
 transport input none
scheduler allocate 60000 1000
end
Router#
1. Make sure that the connection between the router and the switch is trunk.
2. The exclude commands should exclude address range from being assigned to hosts. For example:
# ip dhcp pool (pool name) 192.168.1.1 192.168.1.10. so addresses from 1 to 10 will not be assigned to clients.
3. Default router (ip address)
4. Create a VLAN interface and use the DHCP default router ip address. For example:
default router 192.168.1.1
Interface vlan 100
ip address 192.168.1.1
5. you need an IP helper assigned to the interface that is connected to the switch.
Please refer to the attached guide for more details.
johnd2310
Level 8
Level 8
Which interface connects to your lan?  You might want to assign an ip address to interface vlan1
interface Vlan1
John
**Please rate posts you find helpful**
Interface vlan 100
Hi thank you all,
The mistake was mine at excluded address: I gave 192.x.x.x as well as the 255.255.255.0.
The mask created trouble.
HS
