Newb routing problem 2x1941's
gregbaiocchi
I have 2x 1941's in my home lab with one client on each router. no net connection. I can ping from 1.10 to 2.10 but not the other way around. Any ideas? this is driving me nuts. I can ping all the way to gi0/1 through both s0/1's
R1 has a W10 client on it 192.168.1.10 255.255.255.0
R2 has a Pi on it 192.168.2.10 255.255.255.0
Router1#show run
Building configuration...
Current configuration : 1464 bytes
! Last configuration change at 02:36:02 UTC Thu Apr 6 2017
version 15.4
hostname Router1
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
license udi pid xxx sn xxx
redundancy
ip ssh time-out 50
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
ip virtual-reassembly in
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/0/1
ip address 192.168.3.1 255.255.255.0
clock rate 64000
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.2.0 255.255.255.0 Serial0/0/1
logging host 198.105.254.130
Current configuration : 2303 bytes
! Last configuration change at 02:41:56 UTC Thu Apr 6 2017
version 15.4
hostname Router2
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
redundancy
ip ssh time-out 50
no ip address
shutdown
no ip address
shutdown
duplex auto
speed auto
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
clock rate 2000000
ip address 192.168.3.2 255.255.255.0
no ip http server
ip route 192.168.1.0 255.255.255.0 Serial0/0/1
control-plane
line con 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password cisco
login
transport input none
scheduler allocate 20000 1000
end
16 Replies 16
Dennis Mink
from your 2.10 test the following:
see if you can ping the 2.1
see if you can ping then serial interface of the router
see if you can ping the serial interface of the remote router
see if you can ping the 1.1 on the remote router,
see what works and what doesnt and isolate the problem by braking the path up
please rate if useful
Please remember to rate useful posts, by clicking on the stars below.
forgot to include that...I'm exhausted. yes, I can ping 2.1,3.2,3.1,1.1. so everything but the client
can you ping 2,10 from 2.1
and 2.10 sourced from 3.2?
yes, everything pings except 2.10 to 1.10
Can you ping 1.10 from Router 2 using the source of 2.1 ?
yes.
Router2#ping
Protocol [ip]:
Target IP address: 192.168.1.10
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 192.168.2.1
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 192.168.1.10, timeout is 2 seconds:
Packet sent with a source address of 192.168.2.1
192.168.2.1
Success rate is 100 percent (5/5), round-trip min/avg/max
Hello
Turn off any software firewall on the windows clients or allow them to receive echo-reply
res
Paul
Kind Regards
Paul
tried that.  I can ping from r1 to the 1.10 client but not from client2.10 to client 1.10
gregbaiocchi
I just swapped IPs of the clients and swapped their ports...same thing. I really doubt its a firewall issue.
So when you swapped IPs could you then ping from 1.10 to 2.10 or not.
Jon
Yes...exact same problem as before.
gregbaiocchi
still unsolved...should I post this somewhere else?
Hello
As you are specifiying static routes towards an interface instead of next hop then you'll need proxy arp enabled on each interface your statics point to
so try enabling proxy arp
res
Paul
Kind Regards
Paul
Thanks for the reply.  I set ip proxy-arp on every interface...same issue
