Newb routing problem 2x1941's
gregbaiocchi
I have 2x 1941's in my home lab with one client on each router. no net connection. I can ping from 1.10 to 2.10 but not the other way around. Any ideas? this is driving me nuts. I can ping all the way to gi0/1 through both s0/1's
R1 has a W10 client on it 192.168.1.10 255.255.255.0
R2 has a Pi on it 192.168.2.10 255.255.255.0
Router1#show run
Building configuration...
Current configuration : 1464 bytes
! Last configuration change at 02:36:02 UTC Thu Apr 6 2017
version 15.4
hostname Router1
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
license udi pid xxx sn xxx
redundancy
ip ssh time-out 50
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
ip virtual-reassembly in
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/0/1
ip address 192.168.3.1 255.255.255.0
clock rate 64000
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.2.0 255.255.255.0 Serial0/0/1
logging host 198.105.254.130
Current configuration : 2303 bytes
! Last configuration change at 02:41:56 UTC Thu Apr 6 2017
version 15.4
hostname Router2
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
redundancy
ip ssh time-out 50
no ip address
shutdown
no ip address
shutdown
duplex auto
speed auto
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
clock rate 2000000
ip address 192.168.3.2 255.255.255.0
no ip http server
ip route 192.168.1.0 255.255.255.0 Serial0/0/1
control-plane
line con 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password cisco
login
transport input none
scheduler allocate 20000 1000
end
16 Replies 16
So just to confirm because I worded my last question badly :).
With your original setup you could not ping 1.10 from 2.10. When you swapped IPs on the devices could you then ping 1.10 from 2.10 or not ?
Jon
no i could not. keep in mind,  I only switched the config of the clients not the routers.  thanks for the replies this has been nagging me
