Next hop in ip routing at CE router is not pinging
girish_p1
In my company when I check at CE router, there is some static routing is done on a vrf but the next hope address is not pinging. Neither I am able to see where this next hop address lies. How can I check this IP's interface or where this IP resides in the network.
Have you executed the ping under the VRF, example:
ping vrf TEST 1.1.1.1
Also you can execute show cdp neighbors to see your neighbor IP
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
