10-21-2010 11:03 AM - edited 03-06-2019 01:40 PM
Hi, Cisco Expert
We have some questions about nexus 2248T with 5010.
We designed 12 x server cabinets with 2 network cabinets per row.
each server cabinets has a 2248T on top. and 2 x nexus 5010 in the network cabinets.
question here:
1. how can we connect 2248T between two 5010 for fully redundant?
2. If one 2248T crashed, we buy a new one, connect to 5010,
Thanks.
Solved! Go to Solution.
10-22-2010 07:33 AM
dahua.huang wrote:
great document.
Do you have a link for this from Chapter 1 to end?
Here you go:
http://www.cisco.com/en/US/products/ps9670/products_implementation_design_guides_list.html
Atif
10-21-2010 09:16 PM
dahua.huang wrote:
Hi, Cisco Expert
question here:
Thanks.
Hello Huang,
I will suggest you go through the document available at the following URL for a better understanding of the options available to you as far as connecting FEX to N5K is concerned:
To answer your questions:
Atif
10-22-2010 07:28 AM
great document.
10-22-2010 07:33 AM
dahua.huang wrote:
great document.
Here you go:
Atif
10-22-2010 12:59 PM
One more question.
the links between 5010 and 2248T.
I have to using FET-10G + MMF cable or using twinax. (within 10meter)
Thanks.
10-23-2010 08:34 PM
dahua.huang wrote:
One more question.
Thanks.
FET is cost efficient option of FEX to N5K connectivity but it is not the only option. You can use SFP+ for this connectivity as well which gives you options of using the copper attached SFP+, SFP+ (LR/SR) for distances up to 300metre. Today FEX and N5K can be separated at most by 300m. Distances over 300m are not supported.
Atif
