Nexus 3048 - ERROR: tcam region full
rthakker
I am getting following error whilst updating existing COPP policy to restrict NP, SNMP, SSH etc.. It’s new Cisco Nexus 3048 straight out of box and I am trying to create standard build in LAB first. NX-OS version is
kickstart image file is: bootflash:/n3000-uk9-kickstart.5.0.3.U2.2b.bin
system image file is: bootflash:/n3000-uk9.5.0.3.U2.2b.bin
TestlabL2S01#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
TestlabL2S01(config)# ip access-list copp-system-acl-snmp
TestlabL2S01(config-acl)#  211 permit udp any 10.30.128.71/32 eq snmptrap
TESTLABL2S01# sh log last 10
2013 Apr 25 13:25:08 TESTLABL2S01 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/52, operational Receive Flow Con
trol state changed to off
2013 Apr 25 13:25:08 TESTLABL2S01 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/52, operational Transmit Flow Co
ntrol state changed to off
2013 Apr 25 13:25:08 TESTLABL2S01 %ETHPORT-5-IF_UP: Interface Ethernet1/52 is up in mode access
2013 Apr 25 13:25:24 TESTLABL2S01 %STP-2-BRIDGE_ASSURANCE_BLOCK: Bridge Assurance blocking port Eth1/52 VLAN: 1.
2013 Apr 25 13:25:24 TESTLABL2S01 %STP-2-BRIDGE_ASSURANCE_BLOCK: Bridge Assurance blocking port Eth1/51 VLAN: 1.
2013 Apr 25 13:25:26 TESTLABL2S01 %STP-2-BRIDGE_ASSURANCE_BLOCK: Bridge Assurance blocking port Eth1/50 VLAN: 1.
2013 Apr 25 13:25:28 TESTLABL2S01 %STP-2-BRIDGE_ASSURANCE_BLOCK: Bridge Assurance blocking port Eth1/49 VLAN: 1.
2013 Apr 25 13:27:13 TESTLABL2S01 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by testbed on 192.168.1.1@pts/0
2013 Apr 25 13:27:45 TESTLABL2S01 %ACLMGR-3-ACLMGR_VERIFY_FAIL: Verify failed: client 40000290, tcam region full
2013 Apr 25 13:27:45 TESTLABL2S01 %AFM-3-AFM_VERIFY_FAIL: Access control policy modification at global scope failed
TESTLABL2S01#
TESTLABL2S01#
sh hardware profile tcam region
   sup size =  128
  vacl size =  512
ifacl size =  256
   qos size =  256
rbacl size =    0
  span size =  128
  racl size =  512
e-racl size =  512
e-vacl size =  512
qoslbl size =  512
  ipsg size =  512
arpacl size =  0
TESTLABL2S01#
I tried changing arpacl size from 0 to 128 but i got same error hence reverted back to original as per instructions in
http://www.cisco.com/en/US/docs/switches/datacenter/nexus3000/sw/security/503_u3_1/b_Cisco_n3k_Security_Config_503_u3_1_chapter_01011.html#concept_4377839DC5EC4AA481CD8CEB9B62CE99
Any suggestions how to resolve this issue?
I really appreciate your help.
Ritesh
0 Replies 0
