Nexus 3064 1-Gig 1000BASE-SX Issue
mkriss5681
Sorry if this is a dumb question but I'm new to the Nexus line of products. My issue is that I cannot get a 1 gig fiber link to a 3560 or 3750 to show up as connected after I upgraded my Nexus 3064 to the n3000-uk9.5.0.3.U2.2c NXOS. The 1 gig interfaces worked fine before I did the upgrade, and if I roll back to n3000-uk9.5.0.3.U1.1a they work fine. My 10 gig interfaces work fine. I'm stumped. If I hook up a link runner to the Nexus the interface comes up as connected but if I link it to a 3750 or 3560 I have no luck. I have done all the layer one stuff like verifiy SFP and fiber. And again if I roll back to the old NXOS it works fine.
I've been searching the forum for days and haven't found out anything. Here are a few commands to help out:
interface Ethernet1/3
  switchport mode trunk
  switchport trunk native vlan 555
  speed 1000
TEST-NEXUS(config-if)# show int Eth 1/3 transceiver details
Ethernet1/3
    transceiver is present
    type is 1000base-SX
    name is CISCO-FINISAR
    part number is FTLF8519P2BCL-C4
    revision is A
    serial number is FNS143203RL
    nominal bitrate is 1300 MBit/sec
    Link length supported for 50/125um fiber is 550 m
    Link length supported for 62.5/125um fiber is 270 m
    cisco id is --
    cisco extended id number is 4
    Calibration info not available
Ethernet1/3 is down (Link not connected)
  Hardware: 1000/10000 Ethernet, address: 547f.ee1a.eb8a (bia 547f.ee1a.eb8a)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, 1000 Mb/s, media type is 1G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped never
  Last clearing of "show interface" counters 00:35:35
  30 seconds input rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
  30 seconds output rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  RX
    0 unicast packets  0 multicast packets  0 broadcast packets
    0 input packets  0 bytes
    0 jumbo packets  0 storm suppression packets
    0 giants  0 input error  0 short frame  0 overrun   0 underrun
    0 watchdog  0 if down drop
    0 input with dribble  0 input discard(includes ACL drops)
    0 Rx pause
  TX
    0 output packets  0 bytes
    0 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble
    0 Tx pause
  0 interface resets
Any help would be very much appreciated!
mkriss5681
Just for reference here is what happens when I roll back to the old 5.0(3)U1(1a) NXOS.
TEST-NEXUS# show int Eth1/3
Ethernet1/3 is up
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 1000 Mb/s, media type is 1G
  EtherType is 0x8100
  Last link flapped 00:01:12
  Last clearing of "show interface" counters 00:01:14
  30 seconds input rate 24112 bits/sec, 3014 bytes/sec, 34 packets/sec
  30 seconds output rate 1680 bits/sec, 210 bytes/sec, 1 packets/sec
    input rate 20.61 Kbps, 14 pps; output rate 1.51 Kbps, 1 pps
  RX
    16 unicast packets  2958 multicast packets  3 broadcast packets
    2977 input packets  221905 bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  2 input discard
    0 Rx pause
  TX
    53 unicast packets  135 multicast packets  1 broadcast packets
    189 output packets  18372 bytes
    0 jumbo packets
    0 Tx pause
  1 interface resets
TEST-NEXUS# show int Eth1/3 transceiver details
Ethernet1/3
    type is 1000base-SX
    revision is A
    cisco id is --
Just in case anyone finds this in a seach I had to open a TAC case and a new bug ticket was issued.
I'm having same problem. after upgrading from 5.0.3.U2.2 to 5.0.3.U2.2c, previously working 1G port went down. My 1G port is GLC-LH, and running as L3 port.
I still have an open TAC for this but I have gotten it working on the latest NXOS. You need to disable autonegotate on the far side 3560/3750 switches. On the 3750 it's no auto and on the 3560s I think its "switch nonnegotiate".
