Nexus 3064 Firmware nxos.7.0.3.I4.6.bin
stein9700
I have a Nexus 3064 I want to firmware to nxos.7.0.3.I4.6, direction say I need to Compact the image.
My 3k does not have the option.
old# copy scp:nxos.7.0.3.I4.6.bin bootflash:nxos.7.0.3.I4.6.bin ?
<CR>
source-interface Select source interface
vrf Display per-VRF information
Even on the other 3k I have which is running 7.0.3.l4.6 it doesn't have compact.
I assume I need to compact the bin file because there is not much room in the bootflash:
Question:
How do I compact the bin file without the compact option?
Usage for bootflash://
1060913152 bytes used
589991936 bytes free
1650905088 bytes total
Here is the current version
Software
BIOS: version 2.8.0
loader: version N/A
kickstart: version 6.0(2)U6(7)
system: version 6.0(2)U6(7)
Power Sequencer Firmware:
Module 1: version v1.0
SFP uC: version 2.12
BIOS compile time: 12/22/2015
kickstart image file is: bootflash:///n3000-uk9-kickstart.6.0.2.U6.7.bin
kickstart compile time: 7/28/2016 9:00:00 [07/28/2016 16:40:23]
system image file is: bootflash:///n3000-uk9.6.0.2.U6.7.bin
system compile time: 7/28/2016 9:00:00 [07/28/2016 17:12:38]
Hardware
cisco Nexus 3064 Chassis ("48x10GE + 4x40G Supervisor")
Intel(R) Celeron(R) CPU P4505 @ 1.87GHz with 3665240 kB of memory.
bootflash: 2007040 kB
Reza Sharifi
What is the size if the new image you are trying to load?
Here you go
698629632    May 18 15:07:27 2018  nxos.7.0.3.I4.6.bin
So that worked but I still don't have enough space to upgrade the Switch.
Not sure how to get to nxos.7.0.3.I4.6.bin
thanks
