Nexus 3064 NTP Help
mkriss5681
I'm having a little trouble setting up NTP on our new Nexus 3064s. We are using a local Meinberg M300 as our server and the Nexus 3064 as a client. Before I submitted a TAC I was wondering if the community would mind double checking what I have.
One major issue I've come across is that the Nexus 3064 will only take a 8 character NTP passphrase. We normally use a 32 char MD5 string. I setup a new 8 char passphrase on our Meinberg M300.
I am not using fabric extenders or distribution to other Nexuses. I am using an interface vlan as our management interface per our current network setup. I am using a VRF. Sorry, we use some public IPs so all IPs are xxx'ed out.
Thanks for ther help!
Here is my config:
ntp server xxx.xxx.xxx.xxx prefer use-vrf myMgmtVFR key 20
ntp source-interface  VlanX
ntp authenticate
ntp authentication-key 20 md5 "password" 7
ntp trusted-key 20
ntp logging
I issue the "clock protocol ntp" command but it does not seem to stick in the running config.
Here are some show commands:
(config)# show ntp session status
Last Action Time Stamp     : Mon Mar 12 09:24:05 2012
Last Action                : Commit
Last Action Result         : Fail
Last Action Failure Reason : ntp(0x40370035)- Fabric Distribution not enabled for NTP
(config)# show ntp statistics peer ipaddr xxx.xxx.xxx.xxx
remote host:          xxx.xxx.xxx.xxx (correct IP)
local interface:      Unresolved (unresolved bothers me)
time last received:   23s
time until next send: 12s
reachability change:  695s
packets sent:         27
packets received:     0
bad authentication:   0
bogus origin:         0
duplicate:            0
bad dispersion:       0
bad reference time:   0
candidate order:      0
Source interface:     xxx.xxx.xxx.xxx (correct interface IP)
(config)# show ntp peers
  Peer IP Address               Serv/Peer
xxx.xxx.xxx.xxx               Server (configured)
(config)# show ntp peer-status
Total peers : 1
* - selected for sync, + -  peer mode(active),
- - peer mode(passive), = - polled in client mode
    remote               local                 st   poll   reach delay
=xxx.xxx.xxx.xxx         0.0.0.0                16   16       0   0.00000
# show logging | inc ntp
ntp                     2                       2
2012 Mar 12 10:25:22 HOSTNAME ntpd[4513]: ntp:sendto(xxx.xxx.xxx.xxx): No such device or address
# ping xxx.xxx.xxx.xxx vrf myMgmtVFR
PING xxx.xxx.xxx.xxx (xxx.xxx.xxx.xxx): 56 data bytes
64 bytes from xxx.xxx.xxx.xxx: icmp_seq=0 ttl=62 time=1.285 ms
64 bytes from xxx.xxx.xxx.xxx: icmp_seq=1 ttl=62 time=0.772 ms
64 bytes from xxx.xxx.xxx.xxx: icmp_seq=2 ttl=62 time=0.654 ms
64 bytes from xxx.xxx.xxx.xxx: icmp_seq=3 ttl=62 time=0.774 ms
64 bytes from xxx.xxx.xxx.xxx: icmp_seq=4 ttl=62 time=0.653 ms
# ntp sync-retry
HOSTNAME# 2012 Mar 12 10:22:00.429575 ntp: ntp_process_mts_msg: Opcode received: MTS_OPC_NTP_RETRY_REQ
2012 Mar 12 10:22:00.429832 ntp: Successfully sent SIGKILL to ntpd
2012 Mar 12 10:22:00.430072 ntp: Sending cmi response with return_code = 0x0
2012 Mar 12 10:22:00.430282 ntp: setting global CMI msg req to NULL
2012 Mar 12 10:22:00.431828 ntp: ntp_sigchld_wait_and_fetch_status: waitpid() returns with status of 7632
2012 Mar 12 10:22:00.432654 ntp: ntp_sigchld_wait_and_fetch_status: Got a SIGCHLD from pid : 7632
2012 Mar 12 10:22:00.432860 ntp: ntp_sigchld_wait_and_fetch_status: NTPD PID is 7632
2012 Mar 12 10:22:00.433063 ntp: ntp_sigchld_wait_and_fetch_status: Child exited due a signal, status 9
2012 Mar 12 10:22:00.433268 ntp: ntp_sigchld_wait_and_fetch_status: Child exited with status 0
2012 Mar 12 10:22:00.447248 ntp: ntp_spawn_ntpd: Command: killall ntpd failed with return code 256, errno: 4
2012 Mar 12 10:22:00.447510 ntp: ntp_sigchld_wait_and_fetch_status: waitpid() returns with status of -1
2012 Mar 12 10:22:00.447716 ntp: ntp_sigchld_wait_and_fetch_status: waitpid() failed. No child exited, Errno = 10
2012 Mar 12 10:22:00.453463 ntp: ntp_spawn_ntpd: Parent gets the pid of child: 0
2012 Mar 12 10:22:00.455157 ntp: ntp_spawn_ntpd: Parent gets the pid of child: 7825
2012 Mar 12 10:22:00.455425 ntp: ntp_openhost: connecting to local address 0x100007f
2012 Mar 12 10:22:00.456290 ntp: getnetnum: Obtaining ip for host localhost
2012 Mar 12 10:22:00.456546 ntp: getnetnum: Trying a DNS query before mgmt 0 is up
2012 Mar 12 10:22:00.456751 ntp: ntp_open_events_socket: TO BIND address 2
2012 Mar 12 10:22:00.468321 ntp: ntp_doquery: sendrequest, num attempts = 30
2012 Mar 12 10:22:05.478278 ntp: getresponse: select timed out, nothing received
2012 Mar 12 10:22:05.498271 ntp: ntp_doquery: sendrequest, num attempts = 29
2012 Mar 12 10:22:05.538251 ntp: ntp_doquery: sendrequest, num attempts = 30
2012 Mar 12 10:22:05.578271 ntp: ntp_doquery: sendrequest, num attempts = 30
2012 Mar 12 10:22:05.618253 ntp: ntp_doquery: sendrequest, num attempts = 30
2012 Mar 12 10:22:05.638497 ntp: getnetnum: Obtaining ip for host localhost
2012 Mar 12 10:22:05.638752 ntp: getnetnum: Trying a DNS query before mgmt 0 is up
2012 Mar 12 10:22:05.658302 ntp: ntp_doquery: sendrequest, num attempts = 30
2012 Mar 12 10:22:05.679460 ntp: ntp_config_source_for_sync_retry: Reconfiguring Source IP for ntp sync-retry
2012 Mar 12 10:22:05.698241 ntp: ntp_doquery: sendrequest, num attempts = 30
2012 Mar 12 10:22:05.720703 ntp: ntp_config_source_intf_for_sync_retry: Reconfiguring Source interface for ntp sync-retry
2012 Mar 12 10:22:05.738532 ntp: ntp_doquery: sendrequest, num attempts = 30
2012 Mar 12 10:22:05.759305 ntp: ntp_pss_save_source_interface: 24 bytes sent for CFG_TYPE_NTP_SRC_INTF sync
# show ver
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2012, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 2.4.0
  loader:    version N/A
  kickstart: version 5.0(3)U3(1)
  system:    version 5.0(3)U3(1)
  power-seq: Module 1: version v4.1
  BIOS compile time:       08/29/2011
  kickstart image file is: bootflash:/n3000-uk9-kickstart.5.0.3.U3.1.bin
  kickstart compile time:  2/28/2012 16:00:00 [02/28/2012 20:01:58]
  system image file is:    bootflash:/n3000-uk9.5.0.3.U3.1.bin
  system compile time:     2/28/2012 16:00:00 [02/28/2012 20:58:39]
Hardware
  cisco Nexus3064 Chassis ("48x10GE + 16x10G/4x40G Supervisor")
  Intel(R) Celeron(R) CPU      with 4007284 kB of memory.
  Processor Board ID JAF1523CGKT
  Device name: 400-128-NX-1
  bootflash:    2007040 kB
Kernel uptime is 0 day(s), 0 hour(s), 44 minute(s), 15 second(s)
Last reset at 667819 usecs after  Mon Mar 12 10:23:12 2012
  Reason: Reset Requested by CLI command reload
  System version: 5.0(3)U3(1)
  Service:
plugin
  Core Plugin, Ethernet Plugin
7 Replies 7
Leo Laohoo
What happens if you remove the encryption.  Use the "ntp server 1.2.3.4" only.
I have to verify with a coworker it will work unencrypted but thats a great idea. I'll try that next.
Hmmmm ... Maybe I should've been clearer.
My statement of running without any encryption is just a TEST.  I want to determine, as simple as possible (by removing non-essential lines), if simple NTP lines will or will not work.  It the lines work without configuration, then you narrow down where the issue is.
So this morning I tried a few things. The first is I put a similar config on a 3560 with the new sort NTP keyphrase and it synced. Second I tried unencrypted with the 3560 and it also worked.
On the Nexus 3064 I tried unencrypted and it did not work. This leads me to believe it is another NX-OS bug. I'll be opening a TAC Case.
Thank you for your advice.
Have you tried the command "NTP commit"?
Another thing, I'm not sure if this is related to Bug CSCtt17080.
I did mess around with trying NTP with distribution on and off. I'll admit, only having limited experiences with NXOS and only having hands on experience with the 3064, my knowledge of redistribution is limited at best. I ran ntp distribute followed by ntp commit and it still did not sync.
Good find on the bug ticket. Its for the 7ks but its a very similar issue. I do have an output from sh ntp peers unlike that bug, but I am using a non-default VRF which could be the cause. I'll have to try to get NTP to work on a fresh config with the default VFR and see if that works.
Thanks again for the great advice.
Me too.
