nexus 3064pq nvram error
ALi Nezamifar
hi.
i have a nexus 3064pq.
when switch reload or power on/off startup-configuration is empty .
the full boot log is here :
Version 2.00.1201. Copyright (C) 2009 American Megatrends, Inc.
Press <DEL> or <F2> to enter setup.
Sysconf checksum failed expected; using default valuesPress ctrl L to go to
loader prompt in 2 secs
Booting kickstart image: bootflash:/nxos.9.3.14.bin
CardIndex = 11060
Image valid
graphics_set_kernel_params enter:
Installing klm_card_index
done
[ 4.611554] sd 0:0:0:0: [sda] No Caching mode page found
[ 4.674943] sd 0:0:0:0: [sda] Assuming drive cache: write through
remounting root with size 2048M
creating flash devices BOOT_DEV= sda
INIT: version 2.88 booting
Skipping ata_piix install for n3k.
Unsquashing rootfs ...
Total size needed in bootflash is 113348
check bootflash : OK
Total size needed in bootflash is 41340
Removing libcrdcfgdata and linking libcrdcfgdata3nk
Enabling 8250 serial driver spurious INTs workaround
Installing isan procfs ... done.
Installing SSE module with card index 11060 ... done.
Creating SSE device node 247 ... done.
Inserting kernel_services module ... done.
Making kernel_services character devices
cgroups initialized
is_lxc: is_titan_eor: is_stby: suffix: klm_ftrace: /isanboot/lib/modules/klm_ftrace.o
Installing ftrace in non-lxc mode done
Loading I2C driver ... done.
Loading MEM scrub driver ... done.
Installing CCTRL driver for card_type 30 without NEED_GEM ... Checking for eUSB firmware upgrade..
done.
11.53: Interrupt throttling disabled. No cctrl irq detected.
Loading IGB driver ... eUSB firmware upgrade not required
Checking all filesystems.Current boot disk sda3..
done.
Installing SPROM driver ... 11060 IS_N3K done.
Skipping installing default sprom values for N3k...
Device has less than 4GB bootflash, requires compacted image
Installing pfmsvcs module ...done.
Extracting rpms from image...
Installing nvram module ... done.
Installing if_index module with port mode 1 ... done.
Calling install_tor for TOR
Installing fcfwd stub
Installing RNI lcnd ... done
Installing LC netdev ... Trim files after extracting TOR files ...
done
Installing psdev module ... done.
Installing veobc module ... done.
Checking SR card
Card Index is 11060
Inserting mtdphysmap module...Inserting OBFL module ... done.
Making OBFL character devices
Mounting OBFL pstore for mtd
Fri Jan 29 00:01:39 UTC 2010:: Bad Partition bootflash size 1G too small < min 8G
tune2fs 1.42.9 (28-Dec-2013)
Setting reserved blocks percentage to 0% (0 blocks)
Loading system software
Starting portmap daemon...
creating NFS state directory: done
starting 8 nfsd kernel threads: Saving image for img-sync ...
done
starting mountd: done
starting statd: done
exit code: 1
N3k platforms do not have SSD
Not Micron SSD...
Not Micron SSD...
Installing local RPMS
Patch Repository Setup completed successfully
Creating /dev/mcelog
Starting mcelog daemon
INIT: Entering runlevel: 3
POST Prune of RPMS for Low mem dev
Running S93thirdparty-script...
/etc/init.d/rc: line 294: [: ==: unary operator
Populating conf files for hybrid sysmgr ...
Removing bios-imgs and /lcimages
Starting hybrid sysmgr ...
Netbroker support IS present in the kernel.
done
Skipping EMON in TOR ...
Executing Prune clis.
ethernet switching mode Fri Jan 29 00:01:53 UTC 2010
2010 %$ VDC-1 %$ %%SYSLOG-6-SYSTEM_MSG: Invalid NVRAM Area. Reinit
2010 Jan 29 00:01:57 Bia2Host-3064 %$ VDC-1 %$ %KERN-2-SYSTEM_MSG: [ 13.691263] Initializing NVRAM Block 1 - kernel
2010 Jan 29 00:01:57 Bia2Host-3064 %$ VDC-1 %$ %KERN-2-SYSTEM_MSG: [ 14.424109] Initializing NVRAM Block 2 - kernel
2010 Jan 29 00:01:57 Bia2Host-3064 %$ VDC-1 %$ %KERN-2-SYSTEM_MSG: [ 14.424514] Initializing NVRAM Block 6 - kernel
2010 Jan 29 00:01:57 Bia2Host-3064 %$ VDC-1 %$ %KERN-2-SYSTEM_MSG: [ 14.431758] Initializing NVRAM Block 7 - kernel
2010 Jan 29 00:01:57 Bia2Host-3064 %$ VDC-1 %$ %KERN-2-SYSTEM_MSG: [ 14.432152] Initializing NVRAM Block 11 - kernel
2010 Jan 29 00:01:57 Bia2Host-3064 %$ VDC-1 %$ %KERN-2-SYSTEM_MSG: [ 14.435433] Initializing NVRAM Block 12 - kernel
2010 Jan 29 00:01:57 Bia2Host-3064 %$ VDC-1 %$ %KERN-2-SYSTEM_MSG: [ 14.441451] Initializing NVRAM Block 17 - kernel
2010 Jan 29 00:01:57 Bia2Host-3064 %$ VDC-1 %$ %KERN-2-SYSTEM_MSG: [ 14.460211] Initializing NVRAM Block 18 - kernel
2010 Jan 29 00:01:57 Bia2Host-3064 %$ VDC-1 %$ %KERN-2-SYSTEM_MSG: [ 14.460601] Initializing NVRAM Block 20 - kernel
2010 Jan 29 00:01:57 Bia2Host-3064 %$ VDC-1 %$ %KERN-2-SYSTEM_MSG: [ 14.477495] Initializing NVRAM Block 25 - kernel
2010 Jan 29 00:01:57 Bia2Host-3064 %$ VDC-1 %$ %KERN-2-SYSTEM_MSG: [ 14.477896] Initializing NVRAM Block 26 - kernel
2010 Jan 29 00:01:57 Bia2Host-3064 %$ VDC-1 %$ %KERN-2-SYSTEM_MSG: [ 40.820825] Initializing NVRAM Block 3 - kernel
2010 Jan 29 00:01:57 Bia2Host-3064 %$ VDC-1 %$ %KERN-2-SYSTEM_MSG: [ 40.821017] Initializing NVRAM Block 3 - kernel
2010 Jan 29 00:02:02 Bia2Host-3064 %$ VDC-1 %$ %PLATFORM-2-PS_OK: Power supply 1 ok (Serial number DTN1729P2H2)
2010 Jan 29 00:02:02 Bia2Host-3064 %$ VDC-1 %$ %PLATFORM-2-PS_FANOK: Fan in Power supply 1 ok
2010 Jan 29 00:02:02 Bia2Host-3064 %$ VDC-1 %$ %PLATFORM-2-PS_OK: Power supply 2 ok (Serial number DTN1730P4E0)
2010 Jan 29 00:02:02 Bia2Host-3064 %$ VDC-1 %$ %PLATFORM-2-PS_FANOK: Fan in Power supply 2 ok
2010 Jan 29 00:02:02 Bia2Host-3064 %$ VDC-1 %$ %PLATFORM-2-FANMOD_FAN_OK: Fan module 1 (Fan1(sys_fan1) fan) ok
2010 Jan 29 00:02:04 Bia2Host-3064 %$ VDC-1 %$ %DAEMON-2-SYSTEM_MSG: <<%ASCII-CFG-2-CONF_CONTROL>> Binary restore - ascii-cfg[10885]
2010 Jan 29 00:02:05 Bia2Host-3064 %$ VDC-1 %$ %USER-2-SYSTEM_MSG: Image-Signature Verification disabled by user configuration. Signature of image will not be verified - bootvar
2010 Jan 29 00:02:08 Bia2Host-3064 %$ VDC-1 %$ netstack: Registration with cli server complete
2010 Jan 29 00:02:26 Bia2Host-3064 %$ VDC-1 %$ %USER-2-SYSTEM_MSG: ssnmgr_app_init called on ssnmgr up - aclmgr
2010 Jan 29 00:02:29 Bia2Host-3064 %$ VDC-1 %$ %USER-0-SYSTEM_MSG: DME is not supported for this platform in this release! Disabling DME!! - pltfm_config
2010 Jan 29 00:02:50 Bia2Host-3064 %$ VDC-1 %$ %VDC_MGR-2-VDC_ONLINE: vdc 1 has come online
i think problem in nvram but i dont know how to fix it.
are nvram in eusb storage ?
marce1000
- Do you get a loader> prompt at the end of this sequence ?
 M.
hi again.no dear . boot completed . at the end of sequence when i define some config such as vlans , set clock and password
was deleted and i give poap(yes/no/skip)
