Nexus 3172T How block port by MAC Address
inakiss
I want to block access to the switch by MAC Address, but I don't known how to do it. In many forums appears command "switchport port-security", but my switch doesn't have this option. Does anyone know how to do it?
Switch info:
Hardware
cisco Nexus 3172T Chassis
Intel(R) Pentium(R) CPU @ 2.00GHz with 4029688 kB of memory.
Software
BIOS: version 5.3.1
NXOS: version 9.3(7)
I
You use manaul mac to port secuirty
Not sticky nor dynamic' why?
If you want port secuirty remove mac secure add
Use dynamic with aging time
6 Replies 6
Use mac acl if port-secuirty is not support in this nsk platform.
Do I need to make an ACL for each port?
What are the commands I have to use? I have seen in the manual to use "mac access-list", but I don't have this option in "mac", only "mac ipv6-extract".
I
feature port-security <<- this need
port security support in N3K....TQ..
MAC ACL not support for your platform
You are right, I needed to enable "feature port-security".
Ok, so I configured a port with mac-address security:
switch# configure terminal
switch(config)#  interface Eth1/3
switch(config-if)# feature port-security
Please apply the same port-security config on the peer device also, if VPC is configured
switch(config-if)# switchport port-security mac-address xxxx.xxxx.xxxx
switch(config-if)# switchport port-security violation shutdown
switch(config-if)# exit
switch(config)#
switch#  show running-config port-security
!Command: show running-config port-security
!Running configuration last done at: Tue Feb  6 01:03:07 2001
!Time: Tue Feb  6 01:24:13 2001
version 9.3(7) Bios:version 5.3.1
interface Ethernet1/3
Now, when I connect other device in this port, switch blocked this port. How can I recover this port without reset port security mac?
I
I prefer the manual, because it gives me more control over who has access.
I
