05-09-2016 08:26 AM - edited 03-08-2019 05:40 AM
I am new to this forum and I have a brief question, does the Nexus3548 support QinQ?
Thank you
Mustapha
05-09-2016 09:06 AM
Yes they do
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-3548-switch/data_sheet_c78-707001.html
Cisco Nexus Data Broker |
● Topology support for tap and SPAN aggregation
● Support for QinQ to tag input source tap and SPAN ports
● Traffic load balancing to multiple monitoring tools
● Time stamping using PTP
● Packet truncation
● Traffic filtering based on Layer 1 through Layer 4 header information
● Traffic replication and forwarding to multiple monitoring tools
● Robust RBAC
● Northbound Representational State Transfer (REST) API for all programmability support
05-09-2016 10:13 AM
That's great, would you know which license does it require to configure QinQ? I only have the basic license but if needed I can purchase an upgraded license.
Thank you
Mustapha
07-05-2017 11:46 PM
Hi Mark,
I unable to see the Q in Q will support in your provided link, please cross verify,
● Packet truncation
● Robust RBAC
Hello Mustapha,
I am not seen this feature dot1q-tunnel will support on nexus 3548. Have checked on tool only N7K will support. you can see command in 3548 but you will not able to execute the command & if you try it will prompt you error.
07-06-2017 12:25 AM
It was in that doc a year ago , its been removed , they get updated frequently features added /changed
● Packet truncation
● Robust RBAC
