nexus 3548 fw upgrade power-seq questions
RAINER ADAM
During upgrade of two Nexus 3548 from 9.6.0.2.A6.2 to 9.6.0.2.A6.5a we got the following output:
at006-core01# install all system n3500-uk9.6.0.2.A6.5a.bin kickstart n3500-uk9-kickstart.6.0.2.A6.5a.bin non-interruptive
Installer is forced disruptive
Verifying image bootflash:/n3500-uk9-kickstart.6.0.2.A6.5a.bin for boot variable "kickstart".
[########################################] 100% -- SUCCESS
Verifying image bootflash:/n3500-uk9.6.0.2.A6.5a.bin for boot variable "system".
Verifying image type.
Extracting "system" version from image bootflash:/n3500-uk9.6.0.2.A6.5a.bin.
Extracting "kickstart" version from image bootflash:/n3500-uk9-kickstart.6.0.2.A6.5a.bin.
Extracting "bios" version from image bootflash:/n3500-uk9.6.0.2.A6.5a.bin.
Collecting "running" plugin(s) information.
Collecting plugin(s) information from "new" image.
Performing runtime checks.
Performing module support checks.
Notifying services about system upgrade.
Compatibility check is done:
Module bootable Impact Install-type Reason
1 yes disruptive reset Forced by the user
Images will be upgraded according to following table:
Module Image Running-Version New-Version Upg-Required
1 system 6.0(2)A6(2) 6.0(2)A6(5a) yes
1 kickstart 6.0(2)A6(2) 6.0(2)A6(5a) yes
1 bios v1.9.0(10/13/2012) v1.9.0(10/13/2012) no
1 power-seq v3.1 v2.1 yes
Additional info for this installation:
Service "bfd" : BFD feature is enabled. Upgrade will be disruptive!!!
Switch will be reloaded for disruptive upgrade.
Time Stamp: Sat May 21 10:50:24 2016
Install is in progress, please wait.
Setting boot variables.
Performing configuration copy.
Time Stamp: Sat May 21 10:50:45 2016
Finishing the upgrade, switch will reboot in 10 seconds.
My question:
Whats about the power-seq update? We have yesterday power cycled one of the Nexus switches, but the output was still the same.
A "show version" shows the following:
Software
BIOS: version 1.9.0
loader: version N/A
kickstart: version 6.0(2)A6(5a)
system: version 6.0(2)A6(5a)
Power Sequencer Firmware:
Module 1: version v3.1
BIOS compile time: 10/13/2012
kickstart image file is: bootflash:///n3500-uk9-kickstart.6.0.2.A6.5a.bin
kickstart compile time: 2/13/2016 3:00:00 [02/13/2016 13:35:49]
system image file is: bootflash:///n3500-uk9.6.0.2.A6.5a.bin
system compile time: 2/13/2016 3:00:00 [02/13/2016 14:02:26]
But we have still running the power-seq version v3.1 running. Is this like it should be or is there anything more to do and why is there still a "Upg-Required" YES message?
0 Replies 0
