Nexus 3548 RACL on SVI interface not working with tcp flag
rciowang
Hi All,
I'm working on Nexus 3548 version 7.0(3)I7(3), want to deny tcp syn packages send out from a vlan,
ip access-lists deny-syn
10 deny tcp any any syn
20 permit ip any any
and apply access list to SVI interface's in direction:
ip access-group deny-syn in
but can still make tcp connections, if I remove the syn flag:
10 deny tcp any any
all the tcp flow are blocked. So it seams like tcp flag access list not support on Nexus switch? Or I just mad something wrong.
balaji.bandi
Can you able to post full configuration .
how about below syntax :
Example: Filtering Packets That Contain TCP Flags
The following access list allows TCP packets only if the TCP flags ACK and SYN are set and the FIN flag is not set:
ip access-list extended aaa
 permit tcp any any match-all +ack +syn -fin
 end
The show access-list command has been entered to display the ACL:
Device# show access-list aaa
Extended IP access list aaa
 10 permit tcp any any match-all +ack +syn -fin
BB
Hi balaji,
Sorry for that, I thought it's been really sample configuration, here is full command line output you asked:
# show ip access-lists deny-syn
IP access list deny-syn
# show run interface vlan 2041
!Command: show running-config interface Vlan2041
!Time: Wed Jul 31 14:45:57 2019
version 7.0(3)I7(3)
interface Vlan2041
  no shutdown
  no autostate
  no ip redirects
  ip address 10.41.20.3/24
  ip router ospf 1 area 0.0.0.2
  hsrp 0
    preempt
    priority 105
    ip 10.41.20.1
  hsrp 1
    preempt
    ip 10.41.20.2
