Nexus 3548 x2 Stack
bee7ch
Frequent Visitor
Frequent Visitor
We just unpack our new Nexuses and setup it in the network.
How I can to setup them in stack to access like one dedicated device ?
Or do I need to do vPC and manage it like this?
Mark Malone
Yes Nexus cant stack any of the models ,no need as they have VPC that's what you use
Then also you can connect non VPC switches like a stack of 3850s to each nexus under a standard port-channel there side and a VPC on the Nexus side for full resiliency and load balancing , very stable feature VPC
quick guide how to setup VPC , its 5ks but its same for each model in terms of VPC config
If you get stuck post what you have done i have multiple VPC setups in operation can assist with the config if needed
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/configuration_guide_c07-543563.html
6 Replies 6
Mark Malone
Hello Mark,
And the physical logic is next:
I have 2960 as access switches and I want to connect it to Nexus "stack".
I take two (e1/47, e1/48) links in port-channel from 2960 and put one link (e1/47) in Nexus1 e1/1 and second (e1/48) in Nexus2 e1/1.
Nexus1 e1/1 and in Nexus2 e1/1 - ports are in port-channel, of course.
Yep ?
you really only need 1 link per Nexus side and then 2 links on the individual 2960 , but you could use 4 for throughput resiliency
so would look something like below , the nexus would be in VPC port-channel config while the 2960 just standard PO config
EXAMPLE OF vpc po
interface port-channel15
  description VPC 15 ...........
  switchport mode trunk
  no lacp suspend-individual
  switchport trunk allowed vlan 2,10-11,17-18,20,28,31,33-34,36-39,48,50,64-65,72,74,76,78,80,105
  logging event port link-status
  logging event port trunk-status
  vpc 15
Image result for vpc connected to 2960 switch
Mark,
And I found in manuals that only one of those Nexuses will be in active mode.
Thats mean, network bandwidth between 2960 and Nexus will be only 1G ?
Is it possible to put Nexuses in active-active mode ?
And another subject, I noticed that peer-link is used only for some system traffic etc. and not for normal traffic.
In that case, why there is a 2x 10G links for that ?
I believe that’s if your using peer-gateway setup its active/standby if you have NetApp filers you may require that design because of the way they forward traffic
This is it explained
https://supportforums.cisco.com/t5/network-infrastructure-documents/peer-gateway-feature-on-the-nexus-7000/ta-p/3113290
see this for active/active hsrp in vpc
http://www.ciscozine.com/nexus-vpc-hsrp-vrrp-active-active/
Thank you for your complete explanation قاب گوشی
