Nexus 5000 jumbo frames
Hi All,
We have a requirement to send span traffic to a destination port for monitoring purposes on two 5000s with some 2000 fex boxes attached.
Some of the servers are making use of frames larger than 1500. we have not changed any mtu configuration on the 5000 since installation, and I can see the policy maps is still on 1500.
My first assumption would be that frames larger than 1500 will not be dropped, but it seemingly not (see below). is there a reason why the switch would forward jumbo frames? Also, is there a limitation on MTU for span traffic? There is a MTU command under the span session, but the maximum is 1518. From what I can read the frame will be truncated if it exceeds this. Does that mean the fragments will be dropped?
Thanks!
Jacques
  RX
    7495685816 unicast packets  249 multicast packets  147899 broadcast packets
    7495833963 input packets  1426823388087 bytes
    1608134 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    14601357 unicast packets  84531243 multicast packets  16796989 broadcast packets
    115929589 output packets  41050276352 bytes
    13185803 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause   RX
    0 Rx pause
  TX
    0 Tx pause
Sorry just a correction, I would assume the frames will be dropped if they exceed the MTU of the interface, but apparently they are not.
Thanks!
Jacques
I have this problem too.  Were you able to find an answer?
