Nexus 5000 LAN routing
ApexMicro
All,
So, we have our Nexus as our default gateway (101.1) and the default VLAN1 is setup with two subnets 101.X and 102.X. The DHCP server is using a superscope setup to accomodate the overflow of devices requesting IPs on 101, so when 101 is consumed persons are able to obtain a 102.X IP address. The setup is basic on superscope.
The issue is some times the routing to the firewall with a 102.X is not always 100%. Somedays all goes well and the 102 subnet is routed out to the firewall and its a good day. However, such as today a 102.X address is not routing as it did 24 hours ago. I am perplexed as to why this is behaving unpredicatable.
I would really appreciate input as to why so unpredicatble, and suggested solutions. I can post config, if it helps.
Here is running-config for VLAN1 to show the 102 as secondary address to VLAN1.
interface Vlan1
  no shutdown
  description Shannon Road Main VLAN
  no ip redirects
  ip address 192.168.101.1/24
  ip address 192.168.102.1/24 secondary
  ip router eigrp 1
  ip dhcp relay address 192.168.101.5
Running-config for VLANs
show vlan
VLAN Name                             Status    Ports
1    default                          active    Po10, Eth1/1, Eth1/2, Eth1/3
                                                Eth1/4, Eth1/5, Eth1/6, Eth1/7
                                                Eth1/8, Eth1/9, Eth1/10, Eth1/11
                                                Eth1/12, Eth1/13, Eth1/14
                                                Eth1/15, Eth1/16, Eth1/19
                                                Eth1/20, Eth1/21, Eth1/22
                                                Eth1/23, Eth1/24, Eth1/25
                                                Eth1/26, Eth1/27, Eth1/28
                                                Eth100/1/1, Eth100/1/2
                                                Eth100/1/3, Eth100/1/4
                                                Eth100/1/5, Eth100/1/6
                                                Eth100/1/7, Eth100/1/8
                                                Eth100/1/9, Eth100/1/10
                                                Eth100/1/11, Eth100/1/12
                                                Eth100/1/13, Eth100/1/14
                                                Eth100/1/15, Eth100/1/16
                                                Eth100/1/17, Eth100/1/18
                                                Eth100/1/19, Eth100/1/20
                                                Eth100/1/21, Eth100/1/22
                                                Eth100/1/23, Eth100/1/24
[7m--More-- [27m
                                                Eth100/1/25, Eth100/1/26
                                                Eth100/1/27, Eth100/1/28
                                                Eth100/1/29, Eth100/1/30
                                                Eth100/1/31, Eth100/1/32
                                                Eth100/1/33, Eth100/1/34
                                                Eth100/1/35, Eth100/1/36
                                                Eth100/1/37, Eth100/1/38
                                                Eth100/1/39, Eth100/1/40
                                                Eth100/1/41, Eth100/1/42
                                                Eth100/1/43, Eth100/1/44
                                                Eth100/1/45, Eth100/1/46
                                                Eth100/1/47, Eth100/1/48
99   VLAN0099                         active    Po10, Eth1/1, Eth1/2, Eth1/3
                                                Eth1/4, Eth100/1/48
102  VLAN0102                         active    Po10, Eth1/1, Eth1/2, Eth1/3
                                                Eth1/4, Eth100/1/48
103  VLAN0103                         active    Po10, Eth1/1, Eth1/2, Eth1/3
                                                Eth1/4, Eth100/1/48
104  VLAN0104                         active    Po10, Eth1/1, Eth1/2, Eth1/3
                                                Eth1/4, Eth100/1/48
105  VLAN0105                         active    Po10, Eth1/1, Eth1/2, Eth1/3
                                                Eth1/4, Eth100/1/48
106  VLAN0106                         active    Po10, Eth1/1, Eth1/2, Eth1/3
[7m--More-- [27m
                                                Eth1/4, Eth100/1/48
107  VLAN0107                         active    Po10, Eth1/1, Eth1/2, Eth1/3
                                                Eth1/4, Eth100/1/48
1002 fddi-default                     suspended Po10, Eth1/1, Eth1/2, Eth1/3
                                                Eth1/4, Eth100/1/48
1003 token-ring-default               suspended Po10, Eth1/1, Eth1/2, Eth1/3
                                                Eth1/4, Eth100/1/48
1004 fddinet-default                  suspended Po10, Eth1/1, Eth1/2, Eth1/3
                                                Eth1/4, Eth100/1/48
1005 trnet-default                    suspended Po10, Eth1/1, Eth1/2, Eth1/3
                                                Eth1/4, Eth100/1/48
VLAN Type  Vlan-mode
1    enet  CE
99   enet  CE
102  enet  CE
103  enet  CE
104  enet  CE
105  enet  CE
106  enet  CE
107  enet  CE
1002 enet  CE
[7m--More-- [27m
1003 enet  CE
1004 enet  CE
1005 enet  CE
Remote SPAN VLANs
Reza Sharifi
Have you tried using 2 different vlans with 2 different subnets and see if the same thing happens?
interface Vlan1
  no shutdown
  no ip redirects
   ip router eigrp 1
interface Vlan2
  no shutdown
   no ip redirects
   ip router eigrp 1
Reza,
No, I have not tried using two different yet. I have used the other VLANs listed to test if this was workable solution. However did not get them working as of yet. Hence, why I have posted.
I plan to complete the other VLANs listed so that I can test if the having both subnets on the VLAN1 is cause of unreliable routing. Which perhaps its Friday seems like the logical step. However, wanted to hear from others as to if they have got such working and/or if seen similar.
I appreciate the suggestion.
-Joel Hansen for Dan Reid
