Nexus 5010 debug plugin
dwillynt1
Visitor
The workaround for the bug listed in
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCub15147&from=summary is to load a debug plugin and restart the snmpd process. Can someone please elaborate on where to find the debug plugin?
Bryan Deaver
The debug plugin referenced is not generally available for external consumption.  If you feel you are running into this issue and cannot upgrade to a version with the fix, please work with the TAC to obtain the plugin if necessary.
Thanks for pointing this out in the release-note.  I have updated the release-note to add this additional information.
Bryan
