- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-07-2018 08:33 AM - edited 03-08-2019 04:06 PM
Core10g_1(config)# int po1
Core10g_1(config-if)# no switchport
Error: command not supported on this platform
Am I missing something, because this command is supposed to be supported on the Nexus 5020.
I have searched alot of documentation and nothing points to that the command has been changed in anyway. I am trying to create a L3 interface. Nexus os version n5000-uk9.5.2.1.N1.9a.
feature vpc
feature lacp
feature telnet
feature interface-vlan
feature fex
no feature ssh
inter mgm0
ip address 192.168.101.202/24
no shut
vrf context vpc_keepalive
interface Ethernet1/39-40
switchport access vlan 311
interface Vlan311
vrf member vpc_keepalive
ip address 10.5.31.2/30
no shutdownvpc domain 1
peer-keepalive destination 10.5.31.1 source 10.5.31.2 vrf vpc_keepalive
ip arp synchronize
auto-recovery
peer-switch
interface ether 1/39-40
description ***VPC Peer-Link***
channel-group 1 mode active
no shut
int po 1
switchport mode trunk
vpc peer-link
no shut
Solved! Go to Solution.
- Labels:
LAN Switching
Other Switching
Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-07-2018 11:32 AM
This switch by default is layer-2. If you want to have L-3 capabilities, you need the L-3 daughter card.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-07-2018 11:32 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-07-2018 12:30 PM
Thanks, I looked it up and it seems that the 5010 and 5020 is not capable of routing at all, only the 5500 series works with the module. It never occured to me that the cabilities were not even possible, live and learn thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-07-2018 01:25 PM
Correct. The card only works in 5548 and 5596. The card has been EOL since 2016.
Good Luck!
