11-21-2015 03:04 AM - edited 03-08-2019 02:47 AM
Hi all, Please help
I have nexus 5020 and its ethernet 1/1 are on sfp and its connected to cisco router 1921 0/1.Nexus ethernet 1/1 sfp is 10gb and Router 1921 port is 1GB. for connecting i need to reduce speed.when tried its shows error.Please help me how reduce using command line. On nexus 5020, when i treid to show ip interface brief on eth 1/1 sfp validation failed. please tell me how i can communicate with router through this nexus 1/1 port and if any routing need,please mention that also.This is first time i handle.
04-05-2018 03:24 AM
Upgrade and Downgrade Guidelines
The following guidelines apply to Cisco NX-OS Release 5.0(3)N2(2b), Cisco NX-OS Release 5.0(3)N2(2a), Release 5.0(3)N2(2), and Release 5.0(3)N2(1) for the Cisco Nexus 5000 Series switches:
•Do not change any configuration settings or network settings during the upgrade. Any changes in the network settings may cause a disruptive upgrade.
•Cisco NX-OS Release 5.0(3)N2(2b), Release 5.0(3)N2(2a), Release 5.0(3)N2(2), and Release 5.0(3)N2(1) are ISSU-compatible with NX-OS Release 4.2(1)N1(1) and later releases.
•Downgrading from NX-OS Release 5.0(2) to NX-OS Release 4.2(1) is disruptive.
•Upgrading from NX-OS Release 4.2(1) to NX-OS Release 5.0(2) is a nondisruptive upgrade (ISSU).
•Upgrading from a Cisco NX-OS Release 4.2(1)-based release to Cisco NX-OS Release 5.0(3)N2(2a), Release 5.0(3)N2(2), or Release 5.0(3)N2(1)is nondisruptive.
•Downgrading from Cisco NX-OS Release 5.0(3)N2(2a), Release 5.0(3)N2(2), or Release 5.0(3)N2(1) to a previous release is disruptive.
•When a Layer 3 license is installed, the Cisco Nexus 5500 Platform does not support an ISSU. Hot swapping a Layer 3 module is not supported.
Supported Upgrade and Downgrade Paths
Table 4 shows the upgrade and downgrade possibilities for Cisco NX-OS Release 5.0(3)N2(2b), Release 5.0(3)N2(2a), Release 5.0(3)N2(2a), Release 5.0(3)N2(2), and Release 5.0(3)N2(1):
Upgrading from NX-OS Release 5.0(3)N2(1) to Release 5.0(3)N2(2), Release 5.0(3)N2(2a), or Release 5.0(3)N2(2b) is nondisruptive.
Downgrading from Cisco NX-OS Release 5.0(3)N2(2b), NX-OS Release 5.0(3)N2(2a) or NX-OS Release 5.0(3)N2(2) to NX-OS Release 5.0(3)N2(1) is disruptive.
Table 4 Cisco NX-OS Release 5.0(3)N2(x) Supported Upgrades and Downgrades
Current Cisco
NX-OS Release
Upgrade to NX-OS Release 5.0(3)N2(2b), Relese 5.0(3)N2(2a), Release 5.0(3)N2(2), or Release 5.0(3)N2(1)
Downgrade from NX-OS Release 5.0(3)N2(2b), Release 5.0(3)N2(2a), Release 5.0(3)N2(2), or Release 5.0(3)N2(1)
5.0(3)N1(1c)
5.0(3)N1(1b)
Nondisruptive upgrade (ISSU)
Disruptive downgrade
5.0(2)N2(1)
5.0(2)N1(1)
4.2(1)N2(1a)
4.2(1)N2(1)
4.2(1)N1(1)
