Nexus 5500 routing module utilisation
boris.kudr
Hi community,
Does anyone know how to check utilisation on Nexus 5500 routing module?
Could not find anything in documentation.
Thank you in advance.
Cheers,
Boris
Steve Fuller
Level 9
Level 9
Hi Boris,
I've not found any commands or MIB OIDs that easily provide utilisaiton of the routing module, but the show hardware internal forwarding l3 counters command will show you the port counters for each of the 16 10GE links in the port-channel.
There's some additional information regarding the Nexus 5500 Layer-3 module in the forum post Cisco Nexus 5596UP that might help you understand the architecture etc., if you need it.
