Nexus 5500 SPAN - preserve tagging
jeremy-keen
I have a Nexus 5548 (5.1(3)N2(1a)) that I am configuring a SPAN Session on to capture traffic on a trunked port-channel interface.  I am successfully seeing all packets, however I was also expecting to see the dot1q tagging - but am not.  I seem to recall on the catalyst 6500 platform, there was a command to preserve/send the complete tagged Ethernet frame to a SPAN destination - is the same available on the Nexus 5K platform?
Thanks in advance.
Cheers,
Jeremy
jkilleda
Level 3
Level 3
Hello Jeremy,
Yes , it is available , it is enabled on global basis and you can use the command "show vlan dot1q tag native".
Also you can refer the link below.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5600/sw/layer2/command/cisco_nexus5600_layer2_command_ref/v_commands.html#wp8845924930
