Nexus 5548 Switch error
ossniper
Level 2
Level 2
Hello
I really need help with a cisco nexus 5548 switch.  It's not accepting input from the keyboard.
It keeps showing this messages. I am wondering if it's my console cable or is this a bug or something else.
Picture attached.
I will appreciate a response to fix this up as soon as possible.
Best Regards
Mark Elsen
 - Disconnect all network cables , check if the message goes away then ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Georg Pauwen
try the below:
--> disconnect the console cable
--> shut down the switch
--> reconnect the console cable
--> power on the switch
--> type 'Y' at the prompt and check if the auto provisioning process stops
By the way, 'The message is caused by the Cisco PowerOn Auto Provisioning process. This is a feature that simplifies upgrading software and installing configuration files on new Cisco Nexus switches.'
