nexus 5548 sync issue
remen.mager
Good day!
my first post.. bear with me as I try to explain where I'm stuck. If you need any further info please let me know.
I'm pretty new to the NX-OS, configged several but never in sync with peer.
I'm on a project with a customer who has 2 5548's, in vPC syncing config through peer-link.
so far so good..
I have two switches, the A and the B switch.
the trouble starts when trying a commit or verify :
on the B switch :
cs-lw-n5k-b(config-sync-sp)# sh switch-profile stat
switch-profile  : lw-n5k
Start-time: 853903 usecs after Tue Aug 22 07:27:05 2017
End-time: 213537 usecs after Tue Aug 22 07:27:11 2017
Profile-Revision: 137
Session-type: Commit
Session-subtype: -
Peer-triggered: No
Profile-status: -
Local information:
Status: Verify Success
Error(s):
Peer information:
IP-address: 192.168.168.1
Sync-status: Not yet merged
Merge Flags: pending_merge:1 rcv_merge:0 pending_validate:0
Status: Verify Failure
Error(s):
Validation Failed: Config validation failed as found changes on both sides. rcvd_rev: 0, expected_rev: 0
interface port-channel1
        description cs-lw-n5k-a (Peer-Link)
        speed 10000
interface Ethernet1/1
interface Ethernet1/2
interface Ethernet101/1/1
        spanning-tree port type edge
now it struggles with a few description's, speed and STP.
so I alter the switch-profile to make them the same :
cs-lw-n5k-b(config-sync-sp)# sh switch-profile buffer
Seq-no  Command
1       interface port-channel1
1.1       description cs-lw-n5k-b (Peer-Link)
1.2       speed auto
2       interface Ethernet1/1
2.1       description cs-lw-n5k-b (Peer-Link)
3       interface Ethernet1/2
3.1       description cs-lw-n5k-b (Peer-Link)
4       interface Ethernet101/1/1
4.1       no spanning-tree port type edge
and I commit :
cs-lw-n5k-b(config-sync-sp)# commit
Failed: Verify Failed
Start-time: 299049 usecs after Tue Aug 22 08:21:47 2017
End-time: 282483 usecs after Tue Aug 22 08:21:53 2017
Session-subtype: -
Peer-triggered: No
Profile-status: -
Local information:
Error(s):
Peer information:
Error(s):
could somebody point me in the right direction? thanks a lot!
0 Replies 0
