Nexus 5596 and Fex
opnineopnine
Hello
I have a Nexus 5596 with 21 fex devices connected I know that this version can handle up to 24 Fex, I would like to now how I can check that memory , cpu are ok and not having a over processing for this device.
thanks.
Reza Sharifi
Issue command "sh processes cpu" and at the bottom, it will show you how busy and idle the CPU is
see example below:
CPU util  :   0.0% user,   0.5% kernel,   99.5% idle
Please note that only processes from the requested vdc are shown above
Reza Sharifi
see example below:
