Nexus 5596, weird error
Vinny
I have 2 datacenters running same equipement (two Nexu 5596 with FEX).
I just took a look at the log just to see if everything is ok and I saw that I have the same error message (a lot of times) at both location :
%SYSMGR-FEX100-5-HEARTBEAT_LOSS: Service "satctrl" heartbeat loss 2 ,max 7
I though it was a problem with my peerklink-keepalive connection but I see the word FEX ....so i'm not sure...
Note that at both locations, my Nexus are connected back to back through the management port using transceivers. So it's a copper cable from the first nexus,  going into a transceiver, going to another transceiver in fiber and then back to copper to the other nexus.
Any idea ?
thanks
9 Replies 9
Reza Sharifi
Is VPC keep alive established?
what is the output of "show vpc"?
yes vpc keep alive is established
first datacenter running NX-OS 5.1.3.N1.1 :
Primary core :
CORE1# sh vpc
Legend:
                (*) -  local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 1
Peer  status                     : peer adjacency formed ok
vPC keep-alive  status           : peer is alive
Configuration consistency status:  success
Per-vlan consistency status     : success
Type-2 consistency  status       : success
vPC role                        : primary
Number of  vPCs configured       : 404
Peer Gateway                    : Enabled
Peer  gateway excluded VLANs     : -
Dual-active excluded VLANs      :  -
Graceful Consistency Check      : Enabled
Secondary core :
Core2 # sh vpc
Legend:
vPC domain id                   : 1
vPC role                        : secondary
Second datacenter running NX-OS 5.2.1.N1.1 :
Primary core :
Core1# sh vpc
Legend:
vPC domain id                     : 1
Configuration consistency status  :  success
vPC role                          :  primary
Number of vPCs configured         : 246
Auto-recovery status              : Disabled
Secondary core :
Core2# sh vpc
Legend:
vPC  domain id                     : 1
thank you
same message here, any findings?
I talked to cisco for over a year about this problem (a lot of debugging with them). It's supposed to be fixed in the 6.X release but 6.x is not recommanded at the moment. So they told me to not upgrade right now unless we have problems.
InayathUlla Sharieff
Vincent,
Error:
1.
Heartbeat Issue:
- Satctrl is supposed to punch heartbeat every 5 secs.
- Its allowed to miss upto 7 times (35 secs).
- After 7th miss, it will be killed by sysmgr, fex will be offline.
- Sysmgr sends these syslogs after 2nd miss.
The reason of this heartbeat failure is some other processes in the fex is busy doing some operation and satctrl doesn’t get scheduled to punch heartbeat timely.
Cisco has a software bug to track this issue, when NMS to poll the fex info, sometimes it will lead to heatbeat failure.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCuc39303
HTH Regards
Inayath
*Plz rate if this info is helpfull.
Inayath,
yes it's exactly that. That was the bug id that was created after I spoke to TAC for several months of debugging.
Yes please upgrade to the latest to have this resolved or remove the snmp polling out of the config.
Inayath
*Plz rate all usefull post and close the thread as answered.
Thanks for the help inayath. I had the same query and it helped me.
Fari
sure, thanks, solarwinds and n5000-uk9.5.1.3.N1.1a.bin is my case too, we will try to upgrade,
