11-18-2017 08:02 PM - edited 03-08-2019 12:47 PM
11-18-2017 08:38 PM
Core-N5K-1# show system internal flashdir /mnt/pdd
./ 2048
../ 260
lost+found/ 12288
ssh/ 1024
random-seed 512
.ssh/ 1024
.ssh2/ 1024
plugin_swid_map 4156
callhome.d/ 1024
bootlogs/ 1024
logs/ 18432
cfgctrl_log.txt 258179
psshelper_debug_db.pss 2048
psshelper_debug_db.map 0
psshelper_debug_db.dat 0
psshelper_debug_db.trm 0
res_mgr_config_disk.pss 2048
res_mgr_config_disk.map 512
res_mgr_config_disk.dat 512
res_mgr_config_disk.trm 0
patch_log_version.dat 11
patch_debugs.log 375671
cert_init_debugs.txt 947
cert-store/ 1024
snmp.d/ 1024
vman_fdb_pss.pss 9216
vman_fdb_pss.map 0
vman_fdb_pss.dat 0
vman_fdb_pss.trm 0
ntp.drift 9
pacifica_preissu.txt 36900
installer.log 9416
installer_detail.log 45350
install_all_cli.log 2040
rtdbctrl.log 28546
log_level_debugs 100
core_dump_log 794055
installer.log.1 9416
installer.log.2 9416
infra_convert.log 21058
tmplog 0
installer.log.3 9416
installer_err_id.log 2
install_ialogs_detail.txt 2
installer.log.4 9416
Core-N5K-1# filesys delete /mnt/pss/patch_debugs.log
Please Wait.File is being deleted.
Core-N5K-1# filesys delete /mnt/pss/installer_detail.log
Core-N5K-1# filesys delete /mnt/pss/core_dump_log
Core-N5K-1# install all kickstart bootflash:/n6000-uk9-kickstart.7.1.4.N1.1.bin ssystem bootflash:/n6000-uk9.7.1.4.N1.1.bin
Verifying image bootflash:/n6000-uk9-kickstart.7.1.4.N1.1.bin for boot variable "kickstart".
[# ] 0%[####################] 100% -- SUCCESS
Verifying image bootflash:/n6000-uk9.7.1.4.N1.1.bin for boot variable "system".
Verifying image type.
[# ] 0%[##### ] 20%[####### ] 30%[######### ] 40%[########### ] 50%![########### ] 50%[################### ] 90%[####################] 100%[####################] 100% -- SUCCESS
Extracting "system" version from image bootflash:/n6000-uk9.7.1.4.N1.1.bin.
Extracting "kickstart" version from image bootflash:/n6000-uk9-kickstart.7.1.4.N1.1.bin.
Extracting "bios" version from image bootflash:/n6000-uk9.7.1.4.N1.1.bin.
Performing module support checks.
Notifying services about system upgrade.
Compatibility check is done:
Module bootable Impact Install-type Reason
0 yes disruptive reset Non-disruptive install not supported if L3 was enabled
1 yes disruptive reset Non-disruptive install not supported if L3 was enabled
2 yes disruptive reset Non-disruptive install not supported if L3 was enabled
Images will be upgraded according to following table:
Module Image Running-Version New-Version Upg-Required
0 system 7.1(3)N1(2) 7.1(4)N1(1) yes
0 kickstart 7.1(3)N1(2) 7.1(4)N1(1) yes
0 bios v2.1.0(09/01/2014) v2.6.0(07/22/2016) yes
1 power-seq v2.0 v2.0 no
2 power-seq v2.0 v2.0 no
0 microcontroller v1.2.2.0 v1.2.0.2 no
Switch will be reloaded for disruptive upgrade.
Do you want to continue with the installation (y/n)? [n] ![Jy
