Nexus 5k snmp IfInErrors/IfOutErrors
dong_madsn
I am trying to to graph the errors on Eth1/2 on my Nexus 5K. I do this via the following Oid: .1.3.6.1.2.1.2.2.1.14.IfIndex (for the nexus Eth1/2 int I am using 436211712 as Ifindex) for the input errors. This works brilliant on a router or a switch with the normal IOS. On my Nexus I get some strange results....
On my nexus I get "114" as a result for the input errors, which in it self is okay, the problem is that I cannot find this value looking at the interface.
N5K-1# sh int Eth1/2
Ethernet1/2 is up
  Hardware: 1000/10000 Ethernet, address:
  Description: [N5K-1]
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  reliability 255/255, txload 2/255, rxload 4/255
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 50week(s) 2day(s)
  Last clearing of "show interface" counters 01:44:18
  30 seconds input rate 169236136 bits/sec, 48235 packets/sec
  30 seconds output rate 110784488 bits/sec, 18387 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 186.29 Mbps, 52.00 Kpps; output rate 112.73 Mbps, 19.35 Kpps
  RX
    416641114 unicast packets  152559 multicast packets  48615 broadcast packets
    416842288 input packets  221426676807 bytes
    79910320 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    160665228 unicast packets  304460 multicast packets  65177 broadcast packets
    161034865 output packets  118557528934 bytes
    48860086 jumbo packets
   0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
  0 interface resets
Using the following command sh int ethernet 1/2 counters errors snmp I get:
Port          Align-Err    FCS-Err   Xmit-Err    Rcv-Err  UnderSize OutDiscards
Eth1/2                0          0          0          0          0           0
Port         Single-Col  Multi-Col   Late-Col  Exces-Col  Carri-Sen       Runts
Eth1/2                0          0          0          0          0           0
Port          Giants SQETest-Err Deferred-Tx IntMacTx-Er IntMacRx-Er Symbol-Err
Eth1/2             0          --           0           0           0          0
So I thought I might use the wrong Ifindex, but this also seems to be allright
N5K-1# sh interface snmp-ifindex | inc 1/2
Eth1/2          436211712  (0x1a001000)
As far I can see in the documentation then all interfaces are persistent, so it is the right one.
Running show int counters detailed snmp | in "Input Errors:"
  Input Errors:                                         2
  Input Errors:                                       121
  Input Errors:                                         5
  Input Errors:                                         3
  Input Errors:                                         3
  Input Errors:                                         1
  Input Errors:                                         1
So the 114 is not even an input error, is ther anyone who can tell me how to find the right Oid or help figuring out what it is that I am graphing?
dong_madsn
I did some further investigation. Doing an snmpwalk
snmpwalk -cpublic -v2c 10.3.95.5 1.3.6.1.2.1.2.2.1 | grep 436211712
iso.3.6.1.2.1.2.2.1.1.436211712 = INTEGER: 436211712
iso.3.6.1.2.1.2.2.1.2.436211712 = STRING: "Ethernet1/2"
iso.3.6.1.2.1.2.2.1.3.436211712 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.4.436211712 = INTEGER: 1500
iso.3.6.1.2.1.2.2.1.5.436211712 = Gauge32: 4294967295
iso.3.6.1.2.1.2.2.1.6.436211712 = Hex-STRING: 54 7F EE 5B DC 69
iso.3.6.1.2.1.2.2.1.7.436211712 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.8.436211712 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.9.436211712 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.2.2.1.10.436211712 = Counter32: 4083166049
iso.3.6.1.2.1.2.2.1.11.436211712 = Counter32: 1269147921
iso.3.6.1.2.1.2.2.1.12.436211712 = Counter32: 522286869
iso.3.6.1.2.1.2.2.1.13.436211712 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.436211712 = Counter32: 114
iso.3.6.1.2.1.2.2.1.15.436211712 = Counter32: 0
iso.3.6.1.2.1.2.2.1.16.436211712 = Counter32: 1509434505
iso.3.6.1.2.1.2.2.1.17.436211712 = Counter32: 2608394584
iso.3.6.1.2.1.2.2.1.18.436211712 = Counter32: 761715136
iso.3.6.1.2.1.2.2.1.19.436211712 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.436211712 = Counter32: 3
iso.3.6.1.2.1.2.2.1.21.436211712 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.22.436211712 = OID: ccitt.0
against that interface, alle the values seems to be correct, but i cannot correlate:
with any show commands. Even a clear counters interface ethernet 1/2 does not reset the error counters for (iso.3.6.1.2.1.2.2.1.14 and iso.3.6.1.2.1.2.2.1.20)
but they do reset the counter for sh int ethernet 1/2 counters errors snmp I tested that on another interface which had some errors shown.
Have I found a bug here or?
Aha now I got it with respect to the erorror counters. I now read that SNMP counters cannot be cleared, so the errors might actually be true, the inteface just has been cleared and that is why I cannot refind the value!
