Nexus 5K urgent help
The_guroo_2
Level 2
Level 2
Gents need Cisco 5K (os 7.0) help
We have configured couple of static routes ion 5K which is redistributed in OSPF with core
Scenario is that we want to monitor a physical link as soon as the link goes down, the switch should remove the static routes whiochis redistribute din ospf
is that possible.....i have read that physical tracking is not available in nexus 5K or do we have to do it with EEM can someone please reply and tell me how to do it
Carlos Villagran
Hi!
As far as I know, 5Ks is able to do tracking object, please refer to the following link for detailed configuration:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/unicast/521_N11/cisco_n5k_layer3_ucast_cfg_rel_521_N1_1/l3_object.pdf
Hope it helps, best regards!
JC
