Nexus 5k vpc and ESX LACP block bridged vlan in vDSwitch
I have 2 nexus 5K with vpc and one ESX that connected to nexus with this method: ESX vmnic 5 connected to Nexus1 eth 1/17 , ESX vmnic 7 connected to nexus2 eth 1/17
there is a vpc port-channel between Nexus1 and Nexus2 eth1/17 and a LAG in ESX with vmnic 5,7.
I have problem with VLAN bridge. when I bridge two VLAN in ESX (in Firepower or Mikrotik machine) spanning three protocol in Nexus block both vlan immediately.
what is wrong?
Could you help me please?
thank in advance.
Well I Solved Problem
The problem was BPDUs packets that generated by Firepower or Mikrotik and received by Nexus. so I add "spanning-tree bpdufilter enable" under port-channel.
this is configuration example:
interface port-channel117
     description ESX-14 vmnic 5,7
     switchport mode trunk
     vpc 117
thank Mr. Mesghali "linkedin.com/in/rasoul-mesghali-875a653b " for guidance.
Reza Sharifi
Make sure the vPC/Portchannel running between the Nexus switches and the ESX host is configured as a trunk.
Port-channel is running and ESX is in trunk mode.
There isn't any problem in normal usage. but when I bridge 2 VLAN in ESX, STP block them immediately
I added this config under Port-channel but didn't help:
# spanning-tree port type edge trunk
any idea?
     vpc 117
