Nexus 5K with Fex Issue
kannan.kannan
Hi Team,
We created one temporary fabrix extender for some servers,Now we are removing that fex but When i remove FEX getting like below error.
Nexus 5K# no fex xxx
ERROR: Error: Fabric ports exist for this FEX.
Please let me know what is the procedure for remove this FEX.
Thanks..
Kannan
InayathUlla Sharieff
Kannan,
Kindly check if there is any port active or assigned to the portchannel.
Default all the interfaces of fex.
Example:
Assuming this initial config:
feature lacp
feature vpc
vpc domain 1
peer-keepalive destination 1.1.1.1
feature fex  fex 100
pinning max-links 1
description FEX0100   type "Nexus 2148T"
interface port-channel300 ! - this is the VPC going to the fex
switchport mode fex-fabric
vpc 300
fex associate 100
interface Ethernet1/39 ! - this is one of the physical
interfaces going to the fex
fex associate 100
  channel-group 300
interface Ethernet1/40 ! - this is one of the physical  interfaces going to the fex
fex associate 100
channel-group 300
Do this...
Nexus-5K(config)# no int port-channel 300
2013 June 12  12:06:48 Nexus-5K PFMA-2-FEX_STATUS Fex 100 is  offline
2013 June 12 12:06:48 Nexus-5K NOHMS-2-NOHMS_ENV_FEX_OFFLINE   FEX-100 Off-line (Serial Number JAF1309ABPG)
Nexus-5K(config)# int E1/39 - 40
Nexus-5K(config-if-range)# no switchport mode fex-fabric
Nexus-5K(config-if-range)# no fex associate 100
Nexus-5K(config-if-range)# exit
Nexus-5K(config)# no fex 100
REgards
Inayath
*Plz rate if this is helpfull.
Kannan,
Example:
feature lacp
feature vpc
vpc domain 1
feature fex  fex 100
pinning max-links 1
vpc 300
fex associate 100
fex associate 100
  channel-group 300
fex associate 100
channel-group 300
Do this...
REgards
Inayath
Yes Inayath,
You are right, already done.
Thanks lot.
Hi Inayath,
This was helpful.
Daouda
