10-30-2014 04:25 AM - edited 03-07-2019 09:18 PM
Hi..
I have nexus 5k running software version : 5.0(3) N2(1). I need to configure IPSLA command on this switch but not sure whether this image support. I tried executing " ip sla 2 " command on this switch but it gave error. Pls help me and suggest whether this image support this command. If not, in which version would it work.
10-30-2014 04:32 AM
Anu,
N5K does not support IP SLA.
regards
Inayath
*Plz rate if this is helpfull.
10-30-2014 04:46 AM
Hi Inayath,
Thanks for your quick reply.. so IP SLA does not work on nexus 5k in any of images??
Could you pls share document stating same, i need to share this with my seniors.
10-30-2014 05:50 AM
Confirm that currently N5K doesnt support IP SLA on any of the images.
I dont have any document handy.
Inayath
***Plz dont forget to rate all usefull psts.
10-30-2014 06:28 AM
Hi Inayat..
Thanks agian, actually i need to configure track via tracking ip sla. If ip sla does not in nexus 5k, could you suggest any other option.
Using IPSLA i was trying to monitor icmp for a ip.
pls help.
01-30-2023 11:41 AM
I have Nexus 5ks in which I need to create a user account with read-only but allow for writing on the ports. Not sure how to do this.
