Nexus 6004 EIGRP Relationship between the two switches
Kemal Zuko
Hi All,
I will try to explain this as best as I can. In our current TEST LAB we have a Pair of Cisco ASA5585x running in Active/Passive mode. We use a VRF transit to connect the 10 GB interface to a Pair of Cisco Nexus 6004 (L3) switches running vPC between them. Downstream we also have a pair of Cisco 9372 switches (L2) also running vPC between the two.
As of right now we have EIGRP neighbor relationship formed between the two N6K's and the ASA.
ASA
ciscoasa# sh eigrp neighbors
EIGRP-IPv4 neighbors for process 100
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
1 172.16.230.9 Te0/8.451 12 01:30:25 1 200 0 52
0 172.16.230.10 Te0/8.451 12 01:30:25 1 200 0 48
The ASA formed relationship with both N6K's
SWITCH1
Nexus6-1# sh ip eigrp neighbors vrf inside
IP-EIGRP neighbors for process 100 VRF Inside
(sec) (ms) Cnt Num
0 172.16.8.3 Vlan680 11 01:28:28 1 50 0 45
1 172.16.230.10 Vlan451 13 01:28:28 1 50 0 46
2 172.16.230.11 Vlan451 10 01:28:00 4 50 0 13
Nexus6-1#
SWITCH2
Nexus6-2# sh ip eigrp neighbors vrf Inside
(sec) (ms) Cnt Num
2 172.16.8.2 Vlan680 14 01:30:11 23 138 0 48
0 172.16.230.9 Vlan451 13 01:30:11 480 2880 0 50
1 172.16.230.11 Vlan451 13 01:29:48 1598 5000 0 13
Nexus6-2#
Both Nexus Switches formed EIGRP neighbors using the vPC Peer-Link. There is enough documentation out there that strongly suggest not to use vPC Peer-Links for EIGRP anything.
We do have additional interfaces available on the 6K's that we can use as a cross connect for EIGRP. What we are having trouble understanding how we can force EIGRP traffic over those ports?
Here is a complete Switch config:
Switch1
Nexus6-1# sh run
feature telnet
cfs eth distribute
feature eigrp
feature interface-vlan
feature lacp
feature vpc
feature lldp
vlan 1
vlan 451
name P2P_VRF_SVI
vlan 652
name Management
vlan 680
name Inside
vrf context Inside
vrf context management
ip route 0.0.0.0/0 172.16.52.1
vrf context peer-keepalive
vpc domain 99
role priority 1
peer-keepalive destination 10.200.50.2 source 10.200.50.1 vrf peer-keepalive
delay restore 120
interface Vlan1
interface Vlan451
description Inside p2p to ASA
no shutdown
vrf member Inside
ip address 172.16.230.9/29
ip router eigrp 100
no ip passive-interface eigrp 100
interface Vlan651
interface Vlan680
description Inside Network
no shutdown
vrf member Inside
ip address 172.16.8.2/22
ip router eigrp 100
interface port-channel99
switchport mode trunk
spanning-tree port type network
vpc peer-link
interface port-channel102
vpc 102
interface Ethernet1/1
description vPC Peer Link 1.1
speed auto
channel-group 99
interface Ethernet1/6
interface Ethernet1/7
description vPC Peer Link 1.7 to Nexus 9372 PRI
speed auto
channel-group 102 mode active
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet2/1
description vPC Peer Link 2.1
speed auto
channel-group 99
interface Ethernet2/2
interface Ethernet2/7
description vPC Peer Link 2.1 to Nexus SEC
speed auto
interface Ethernet2/8
interface Ethernet8/1
description keep-alive peer-link to ALNSWI02
no switchport
vrf member peer-keepalive
ip address 10.200.50.1/30
interface Ethernet8/2
description Uplink to ASA
interface Ethernet8/3
interface mgmt0
vrf member management
ip address 172.16.52.3/23
line console
line vty
boot kickstart bootflash:/n6000-uk9-kickstart.7.0.1.N1.1.bin
boot system bootflash:/n6000-uk9.7.0.1.N1.1.bin
router eigrp 100
passive-interface default
default-information originate
vrf Inside
autonomous-system 100
poap transit
Nexus6-1#
(sec) (ms) Cnt Num
Nexus6-1#
Nexus6-1# sh ip eigrp topology vrf Inside
IP-EIGRP Topology Table for AS(100)/ID(172.16.8.2) VRF Inside
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 172.16.8.0/22, 1 successors, FD is 2816
via Connected, Vlan680
P 172.16.230.8/29, 1 successors, FD is 2816
via Connected, Vlan451
Nexus6-1# sh vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 99
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 1
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Disabled
vPC Peer-link status
id Port Status Active vlans
1 Po99 up 1,451,652,680
vPC status
id Port Status Consistency Reason Active vlans
102 Po102 up success success 1,451,652,6
80
Nexus6-1# sh spanning-tree
VLAN0001
Spanning tree enabled protocol rstp
Root ID Priority 32769
Address 1005.caf5.88ff
Cost 2
Port 4197 (port-channel102)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Address 8c60.4f2d.2ffc
Interface Role Sts Cost Prio.Nbr Type
Po99 Desg FWD 1 128.4194 (vPC peer-link) Network P2p
Po102 Root FWD 1 128.4197 (vPC) P2p
Eth8/2 Desg FWD 2 128.1026 P2p
Eth8/3 Desg FWD 2 128.1027 P2p
VLAN0451
Root ID Priority 33219
This bridge is the root
Bridge ID Priority 33219 (priority 32768 sys-id-ext 451)
Po102 Desg FWD 1 128.4197 (vPC) P2p
VLAN0652
Root ID Priority 33420
Cost 2
Bridge ID Priority 33420 (priority 32768 sys-id-ext 652)
VLAN0680
Root ID Priority 33448
Cost 2
Bridge ID Priority 33448 (priority 32768 sys-id-ext 680)
Nexus6-1#
Switch2
Nexus6-2# sh run
!Command: show running-config
!Time: Sat Feb 12 19:02:44 2011
version 7.0(1)N1(1)
hostname Nexus6-2
feature telnet
cfs eth distribute
feature eigrp
feature lacp
feature vpc
feature lldp
vlan 1
vlan 451
name P2P_VRF_SVI
vlan 652
name Management
vlan 680
name Inside
vrf context Inside
vrf context P2P_Inside_VRF
vpc domain 99
role priority 2
peer-keepalive destination 10.200.50.1 source 10.200.50.2 vrf peer-keepalive
delay restore 120
interface Vlan1
interface Vlan451
no shutdown
vrf member Inside
ip address 172.16.230.10/29
ip router eigrp 100
interface Vlan680
no shutdown
vrf member Inside
ip address 172.16.8.3/22
ip router eigrp 100
vpc peer-link
vpc 102
speed auto
channel-group 99
interface Ethernet1/2
description vPC Link 1.7 to Nexus 9372 SEC
speed auto
interface Ethernet1/12
speed auto
channel-group 99
interface Ethernet2/6
description vPC Link 2.1 to Nexus PRI
speed auto
interface Ethernet2/12
description keep-alive peer-link to ALNSWI01
no switchport
ip address 10.200.50.2/30
switchport trunk allowed vlan 1,451,652,680
interface Ethernet8/20
interface mgmt0
ip address 172.16.52.4/23
line console
line vty
router eigrp 100
vrf Inside
poap transit
logging logfile messages 6
Nexus6-2#
Nexus6-2#
(sec) (ms) Cnt Num
Nexus6-2#
Nexus6-2# sh ip eigrp topology vrf Inside
IP-EIGRP Topology Table for AS(100)/ID(172.16.8.3) VRF Inside
Nexus6-2#
Nexus6-2#
Nexus6-2# sh vpc
Legend:
vPC domain id : 99
vPC role : secondary
vPC status
80
Nexus6-2#
Nexus6-2#
Nexus6-2# sh spanning-tree
VLAN0001
Cost 3
Port 4194 (port-channel99)
Address 8c60.4f2d.777c
Po99 Root FWD 1 128.4194 (vPC peer-link) Network P2p
VLAN0451
Cost 1
VLAN0652
Cost 3
VLAN0680
Cost 3
Nexus6-2#
Because we run DMVPN in our network we need to be able to advertise the EIGRP networks on our core switch (Nexus 6004's). This technology is very new to us so any help, direction, and advice will be greatly appreciated.
Thank you in advance
43 Replies 43
Reza Sharifi
So, you probably have one or 2 links in a Portchannel that you are using for your VPC peer-link.
You also need a separate link (Could be 10 or 40Gig) for your EIGRP peering. You then put the firewalls and 2 6ks in a /28 subnet (all in one vlan), and than exclude this vlan from your VPC peer-link.
Hi Reza,
Correct, I have two 40GB interfaces participating in vPC over a portchannel 99
Yes, I can have a link between the two Nexus Platforms for my EIGRP. This is where it will get a little confusing.
Eventually we will have a bunch of VRF's going upstream to the ASA for inspection.
VRF's:
DMZ
Inside
VPN
Accounting
IT
Each VRF will be put in a transit vlan that will go up to the ASA for inspection. Each transit vlan consists of seperate /29 networks.
When you say"  You then put the firewalls and 2 6ks in a /28 subnet (all in one vlan), and than exclude this vlan from your VPC peer-link." how can I accomplish this with the design that we have proposed?
Thank you
Have not done vrf on 6ks.  So, if I and saying something that is not correct, you can ignore it.  Since you will have multiple vrfs that need to transit to the firewalls, you probably need to have a vlan with a corresponding /28 subnet per VRF.
So, for example for vrf DMZ, you use one vlan (20) and ip address 192.168.1.0/29.  This vlan would span across the 6ks and the firewalls and the vlan interface belong to vrf DMZ.
For VRF inside you create another vlan (30) and IP address 192.168.2.0/29.  This vlan would span across the 6ks and the firewalls and the vlan interface belong to vrf DMZ.
You than exclude vlan 20 and 30 from the VPC peer-link.
Does it make sense?
That is correct
We would have something like this in place
DMZ -----
vlan 450
name Peer-to-Peer-VLAN
vlan 600
name DMZ
vrf contect DMZ
interface Vlan450
description DMZ p2p to ASA
no shutdown
vrf member DMZ
ip address 172.16.230.1/29
ip router eigrp 100
interface Vlan600
description DMZ Network
no shutdown
vrf member DMZ
ip address 172.16.0.2/22
ip router eigrp 100
INSIDE -----
vlan 451
vlan 680
name Inside
vrf context Inside
interface Vlan451
no shutdown
vrf member Inside
ip router eigrp 100
interface Vlan680
no shutdown
vrf member Inside
ip router eigrp 100
My only confusion is I cant find an example of how to exclude these vlans from vPC to save my life
I am assuming all vlans are allowed (and should be) in your VPC peer-link.
So, if this is the case, you simply go to the portchannel 90 and remove these vlans.
config t
inter po90
switchport trunk allow vlan remove 20, 30
verify with "sh run int po90" that these vlans do not exist.
Raza,
That is correct the PO99 is configured for switchport mode trunk allowing all vlans through. I will have to run the cable tomorrow between the two devices and I can then configure the suggested commands.
Thank you for the help. I will let you know how it went.
Just to clarify this does mean you need to change the connection to your firewalls as well.
If the vlans are transit vlans to the firewalls then you cannot use a vPC to connect the firewalls if those vlans are being removed off the vPC peer link.
Apologies if you already knew this but just wanted to make sure.
Jon
Jon,
Thanks for bringing that up. I did not know that. We just got the new hardware and I never worked on a nexus platform before.
Can you clarify what you mean by your statement that I need to change my connection to the Firewalls as well?
As of right now we have a tenGigabit interface going down to the Nexus that will carry all transit vlans for inspection. Just to clarify, we are not running vPC between the Nexus and the ASA's
Sorry if this sounds all confusing..
My mistake.
I thought you had connected the firewalls to the Nexus switches using a vPC or where using a vPC vlan to make the connection.
If you aren't using a vPC then you just need to make sure as Reza says that you use a different link for the vlans you want to send to the firewalls ie. they cannot be vPC vlans.
Jon
Jon,
No worries, I am glad you brought it up. It does not hurt to know additional information on what if's.
We will implement today and will let you know :)
Appreciate the help from both of you!!!!
I also have one more question. We have been doing some research and came across one article where it mentions if we do HSRP on the Nexus 6000 then we will force all traffic via one switch and would not need to worry about L3 traversing the vPC link for EIGRP.
Any take on that?
Do you mean traffic from the ASA ?
Can you point to the article because my understanding is it does not force traffic to one switch or the other.
I'm not sure what the question is in relation to ie. is it about traffic to and from the firewalls ?
Jon
Yes,
the traffic from ASA after inspection.
http://www.netcraftsmen.com/designing-vpc-and-routing/
is you go down to DRILLING DOWN ON VPC ROUTING it talks about FHRP
Can you just clarify.
You have pointed to a document about vPC. Are you proposing to connect each firewall with a vPC or the active firewall to one Nexus switch and the passive firewall to the other.
And in addition, even if you aren't going to be using a vPC are you saying that you want to allow vPC vlans to the ASAs ?
Jon
