Cisco Bug: CSCtf85481 - Sup6L-E reloads silently
m.teixeira
Hello CISCO networkers,
I'm currently troubleshooting a couple CAT 4500-E series with the supervisor SUP6L-E that seems to fall under this bug conditions...
Unfortunetly i don't have the means to open a TAC case.
Before i order new supervisors, is there any way to be sure about this defect beeing present on the hardware ?
Thank you
Yes, I checked few more information internally on it. As i said earlier we recommend fix on failure that means not all boards may fail due to this.
But if it is failing silently, then you need to get it replaced. Else it is okay.
Hope this clarifies.
Madhu.
7 Replies 7
Hi there,
Could you please share below
sh mod
sh idprom all
sh ver
Madhu
Edited... output posted...
Hello again,
I just got permission from client to post this.
Please find attached the output requested for both catalyst
Thank you once more
EDITED to remove attachments (sorry, client asked to do it)
I looked at the attachment and it is a match for this bug.
Please note due to variability in the hardware not all boards will fail due to
 this issue.   We recommend a fix on failure.  So if it is reloading silently you may consider replacing it.
Hope this helps.
M
Kindly mark it as answered if it helped you.
M
Hi Madhukrishnan,
Thankl you for your help. Is your observation based on anything else more then what is already described in that bugid ?
I mean, i already had managed to arrive at the conclusion that the board did match that bug prerequisites (hardware version, etc). Do you have any non official info that confirms it is affected ?
And is it normal to work well several years before it fails ?
Madhu.
