Nexus 7000 10Gig card not seeing transceiver module?
syannetwork
I'm unable to get the N7K-M108X2-12L 10 Gbps Ethernet XL Module within our Nexus 7009 chassis to recognise the individual X2-10GB-SR transceiver modules. I have the same issue on another 7009 chassis.
If I perform a 'show interface'. I get the following output saying SFP not inserted.
Ethernet3/5 is down (SFP not inserted)
Dedicated Interface
Belongs to Po51
Hardware: 10000 Ethernet, address: 7081.0599.d458 (bia 7081.0599.d458)
I also get the same result if I issue the following command.  Are their any additional features I need to enable? or would this be a license issue?
Have already tried different X2-10GB-SR modules, reloading the card, re seating the card.  I have the same problem on a 2nd Nexus system :-(
sh int trans
Ethernet3/1
    transceiver is not present
Ethernet3/2
Ethernet3/3
Ethernet3/4
Ethernet3/5
Ethernet3/6
Ethernet3/7
Ethernet3/8
6 Replies 6
nkarpysh
What is your NX-OS?
I mean if that support it as per table below:
http://www.cisco.com/en/US/partner/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6974.html#wp62311
Nik
HTH,
Niko
Thanks Nik,
system:    version 5.2(1)
According to Cisco compatibility matrix should be supported.  Anything after 5.0 should be ok.
Can be HW related. All should be supported I guess. Please open TAC case to consider RMA posibility. I understand two different switches showing it but who knows.
NIk
HTH,
Niko
hi
i'm having the same issue , have you managed to solve the problem?
Yes it was resolved, Transceiver was not seated correctly. It looks like it was, but required a firmer push to completely seat it correctly.
ohh thanks , but i tried to fix it with a good push , but it did not work . i will try again tomorrow
thanks for you swift reply ...
ali
