12-14-2011 08:08 AM - edited 03-07-2019 03:53 AM
I am trying the connection above using 10G spf connectors.
Is there any special configuration in order to have a trunk (with 2 disctinct vlans) betwen NX7000 and DELL 6224 ?
Solved! Go to Solution.
08-13-2012 10:27 AM
Good Luck
Alessio
PS: thanks Jeye, i am really tired
08-13-2012 11:07 AM
HI Rosa,
i would not implement it because it is not supported and known. If an issue happened with it, it could be even difficult to troubleshoot.
http://www.cisco.com/en/US/tech/tk389/tk689/tk301/tsd_technology_support_sub-protocol_home.html
very interesting wikipedia
http://en.wikipedia.org/wiki/Multiple_Registration_Protocol
If you need to implement something like that, better you go for some very good IEEE 802.1ak documentation...
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_cfg_mvrp.html
http://www.ieee802.org/1/pages/802.1ak.html
It's my attitude to implement only what is on RFC standard. This anyway is your personal choice.
Take Care
Alessio
PS: don't....don't....
08-15-2012 12:06 PM
I think that will work. Your Dell will expect the data is coming from native VLAN.
jerry
12-16-2011 01:06 PM
The commands to configure a trunk on the Nexus 7000 are as follows for interface ethernet 2/1:
switch(config)# interface ethernet 2/1
switch(config-if)# switchport mode trunk
The native vlan is 1 by default, but to change the native vlan use the following command to change to vlan 2:
switch(config-if)# switchport trunk native vlan 2
By default all vlans are allowed on the trunk. If you want to restrict which vlans are allowed on the trunk use the following command to allow vlans 2-10:
switch(config-if)# switchport trunk allowed vlan 2-10
12-16-2011 02:07 PM
On top of Jim's response. Here is my question: What STP protocol is the Dell using? MST? RSTP?
If you are using RSTP on the Dell, you have to allow VLAN 1 from the trunk because Cisco switches use PVST+RSTP but switches like Dell will use CST RSTP. The CST switches will use VLAN 1 to send and receive control traffic.
jerry
08-13-2012 09:44 AM
My first test:
1. I have started with ethernet ports on booth sides;
2. I have created a vlan id=6 on Dell;
configure
vlan database
vlan 6
exit
3. DELL 6224 port config
configure
interface ethernet 1/g1
switchport general allowed vlan add 6
exit
4. NEXUS 7000 is running Server VTP Operating Mode, VTP V2 Mode
interface Vlan6
no shutdown
description vlan test
ip access-group vlan199_access_in in
ip access-group vlan6_access_out out
ip address 17.35.6.200/24
4. NEXUS 7000 port config:
interface Ethernet10/26
description Teste DELL 6224
switchport access vlan 6
no shutdown
5. I connected tp cable on DELL eth 1/g1
6. I connected tp cable on NEXUS eth 10/26
Result:
Vlan id=6 on NEXUS was automatically removed
08-13-2012 10:27 AM
Good Luck
Alessio
08-13-2012 10:57 AM
Thanks you all for your help.
I have gotten this recoemmendation from DELL Team:
Something else to change would be on the Cisco switch change from VTP to GVRP.
"Dell PowerConnect switches use the standards-based GARP VLAN registration
protocol (GVRP) for dynamic exchange of VLAN configuration information.
PowerConnect Application Note #4: VLAN Interoperability
www.dell.com/networking
Because the Dell and Cisco switches use different protocols by default, no exchange of VLAN control
traffic will take place – and thus no intra-VLAN traffic will flow between the Dell and Cisco switches.
By disabling VTP and enabling GVRP on the Cisco switch, it is possible to exchange intra-VLAN data and
control information in mixed Dell-Cisco environments."
www.dell.com/.../app_note_4.pdf
---------> as I have a Cisco stack (a NEXUS7000 as root plus 4 Cisco 6509 as leaves) I must understand wich kind of side effects I could got beside changing from VTP to GVRP !
What do you think about ?
Rosa
08-13-2012 11:07 AM
HI Rosa,
Take Care
Alessio
08-13-2012 11:18 AM
Alessio your advice is really very cute !
Let me learn about it.
Thanks again.
Rosa
08-13-2012 11:16 AM
Any reason you can't turn off VTP or GVRP completely?
The BP for Nexus is if you don't need VTP, don't turn it on at all.
If you network is not 50+ L2 switches all running VTP server/client mode. You should be able to add/remove VLANs manually.
jerry
08-13-2012 11:26 AM
Jerry my net is hundred per cent server/client.
In fact, I am affraid of these nonstandard components may compromise operational reliability.
Rosa
08-13-2012 11:39 AM
Hi Rosa,
I don't know what to tell you about Dell. But I think you can leave those on transparent/off and configure the VLANs manually. This should not affect your existing VTP server/client network.
jerry
08-15-2012 10:28 AM
Jerry, in extreme circunstances, can I fiber connect NX7000 and DELL (10G spf connectors - both sides) with a single vlan without configuring trunk on interfaces? Just like a simple uplink to a dumb switch ?
Easier as :
no shutdown
Rosa
08-15-2012 12:06 PM
jerry
08-17-2012 06:37 AM
Thanks for your help.
Rosa
