Nexus 7000 and Nexus 2000
pivetta066203
I have one nexus 7000 with F2 blade and FEX 2248TP-E using VDC feature.  I have setup all FEX configuration but the communication between 7000 and 2000 is down. The physical connection doesn't work.
We change the fiber and sfps but the problem is the same. Can you help?
Leo Laohoo
Your interface(s) connecting to the FEX, did you specify the speed?
Reza Sharifi
1-Can you try crossing the strands around on one side of the connection?
2-Are you using FET or standard SFP+ to connect the 7k to 2ks? If it is FET, both sides of the connections must be the same?
3-Do you have the right fiber cables? SM SFP with SM fiber and MM SFP with Multimode fiber.
