Nexus 7000 FabricPath LID
schitrakar
Is there a CLI command to find out LID of an interface Nexus 7000 uses in the fabric path header (OSA) ?
Yes, you can check by using " show VPC " command.
Example :
switch1# show vpc
vPC status
id   Port   Status Consistency Reason           Active vlans  vPC+ Attribute
10   Po10   up     success     success          59-94         DF: No, FP
                                                             MAC:
                                                             50.12.4513
=============>4513 is LID for vPC 10
VS.Suresh.
*Plz rate the usefull posts.
