High cpu utilization on 7206VXR/ NPG-1
Cpu always hitting 70% to 80 % and interrrupt traffic is 70%. Want to know the root cause for this issue.
Tech support is attached for your analyze.  please help me here.
CPU utilization for five seconds: 73%/65%; one minute: 71%; five minutes: 67%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1           8        59        135  0.00%  0.00%  0.00%   0 Chunk Manager
   2       58864   3290773         17  0.00%  0.00%  0.00%   0 Load Meter
   3        1784    238001          7  0.07%  0.01%  0.00%   2 Virtual Exec
   4           0         1          0  0.00%  0.00%  0.00%   0 EDDRI_MAIN
   5     5855500   1701715       3440  0.00%  0.01%  0.00%   0 Check heaps
   6        7032     95017         74  0.00%  0.00%  0.00%   0 Pool Manager
   7           0         2          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
   8           0         2          0  0.00%  0.00%  0.00%   0 Timers
   9           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  10           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  11           0         2          0  0.00%  0.00%  0.00%   0 ATM AutoVC Perio
  12           0         2          0  0.00%  0.00%  0.00%   0 ATM VC Auto Crea
  13           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  14      710988  16441320         43  0.00%  0.00%  0.00%   0 EnvMon
  15           0         1          0  0.00%  0.00%  0.00%   0 OIR Handler
  16         580    274258          2  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  17           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  18       85464  16440614          5  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  19       47392  16440585          2  0.00%  0.00%  0.00%   0 IPC Deferred Por
  20           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  21      435020   3808098        114  0.00%  0.00%  0.00%   0 ARP Input
  22      113028   4079632         27  0.00%  0.00%  0.00%   0 HC Counter Timer
  23           0         2          0  0.00%  0.00%  0.00%   0 DDR Timers
  24           4         4       1000  0.00%  0.00%  0.00%   0 Entity MIB API
  25           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  26       80888  16440570          4  0.00%  0.00%  0.00%   0 GraphIt
  27           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  28           0         3          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  29    30112352   5746934       5239  0.07%  0.13%  0.10%   0 Net Background
  30         252      1382        182  0.00%  0.00%  0.00%   0 Logger
  31      152804  16440549          9  0.00%  0.00%  0.00%   0 TTY Background
  32     9165828  16451271        557  0.15%  0.02%  0.00%   0 Per-Second Jobs
  33           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  34           0         1          0  0.00%  0.00%  0.00%   0 CSP Timer
  35           0         1          0  0.00%  0.00%  0.00%   0 SONET alarm time
  36           0         2          0  0.00%  0.00%  0.00%   0 VNM DSPRM MAIN
  37           0         1          0  0.00%  0.00%  0.00%   0 CES Line Conditi
  38           0         2          0  0.00%  0.00%  0.00%   0 Flash MIB Update
  39           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM Input
  40           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM TIMER
  41           4       418          9  0.00%  0.00%  0.00%   0 TurboACL
  42         224      1964        114  0.00%  0.00%  0.00%   0 AAA Server
  43         300      2630        114  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  44           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  45           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  46   822800444-1245556834          0  7.43%  6.98%  6.60%   0 IP Input
  47           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  48         512      3692        138  0.00%  0.00%  0.00%   0 TACACS+
  49           0         1          0  0.00%  0.00%  0.00%   0 SSS Manager
  50        6016   2193933          2  0.00%  0.00%  0.00%   0 SSS Test Client
  51           0         3          0  0.00%  0.00%  0.00%   0 PPP Hooks
  52           0         1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
  53           0         1          0  0.00%  0.00%  0.00%   0 VPDN call manage
  54      177856    295191        602  0.00%  0.00%  0.00%   0 IP Background
  55        9348    274648         34  0.00%  0.00%  0.00%   0 IP RIB Update
  56           0         2          0  0.00%  0.00%  0.00%   0 SNMP Timers
  57           0         2          0  0.00%  0.00%  0.00%   0 PPP IP Route
  58           0         2          0  0.00%  0.00%  0.00%   0 PPP IPCP
  59        8896    274298         32  0.00%  0.00%  0.00%   0 Adj Manager
  60       50216   1214216         41  0.00%  0.00%  0.00%   0 CEF process
  61      260824   9730071         26  0.00%  0.00%  0.00%   0 TCP Timer
  62       17064     71428        238  0.00%  0.00%  0.00%   0 TCP Protocols
  63           0         1          0  0.00%  0.00%  0.00%   0 Socket Timers
  64         336     54854          6  0.00%  0.00%  0.00%   0 HTTP CORE
  65           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
  66    42879512 321782490        133  0.23%  0.29%  0.23%   0 IP NAT Ager
  67     1997908    274201       7286  0.00%  0.00%  0.00%   0 IP Cache Ager
  68           0         1          0  0.00%  0.00%  0.00%   0 COPS
  69           0         2          0  0.00%  0.00%  0.00%   0 PPP SSS
  70           4         2       2000  0.00%  0.00%  0.00%   0 PPP Bind
  71           0         1          0  0.00%  0.00%  0.00%   0 PAD InCall
  72           0         2          0  0.00%  0.00%  0.00%   0 X.25 Background
  73           0         2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
  74      144060  16440905          8  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
  75           0         1          0  0.00%  0.00%  0.00%   0 bsm_timers
  76       40448  16440542          2  0.00%  0.00%  0.00%   0 bsm_xmt_proc
  77           0         2          0  0.00%  0.00%  0.00%   0 RLM groups Proce
  78           0         3          0  0.00%  0.00%  0.00%   0 gk process
  79           0         1          0  0.00%  0.00%  0.00%   0 Border Element p
  80        3592    658237          5  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
  81          12        43        279  0.00%  0.00%  0.00%   0 LOCAL AAA
  82           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
  83           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
  84       11628     16331        712  0.00%  0.00%  0.00%   0 TPLUS
  85         484     33334         14  0.00%  0.00%  0.00%   0 CEF Scanner
  86           0         2          0  0.00%  0.00%  0.00%   0 ASNL
  87           0         2          0  0.00%  0.00%  0.00%   0 VSP_MGR
  88           0         1          0  0.00%  0.00%  0.00%   0 VoIP AAA
  89           0         1          0  0.00%  0.00%  0.00%   0 QOS_MODULE_MAIN
  90           0         1          0  0.00%  0.00%  0.00%   0 RPMS_PROC_MAIN
  91           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_HTSP
  92           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_R2
  93           0         1          0  0.00%  0.00%  0.00%   0 CCSWVOICE
  94           0         1          0  0.00%  0.00%  0.00%   0 sssapp
  95           0         1          0  0.00%  0.00%  0.00%   0 http client proc
  96      170744   3958550         43  0.00%  0.00%  0.00%   0 traffic_shape
  97           0         2          0  0.00%  0.00%  0.00%   0 Proxy Session Ap
  98        3076   1645411          1  0.00%  0.00%  0.00%   0 RMON Recycle Pro
  99           0         2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
100           0         1          0  0.00%  0.00%  0.00%   0 SYSMGT Events
101         196       956        205  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
102           0         1          0  0.00%  0.00%  0.00%   0 RMON Packets
103    10137352-337816004          0  0.07%  0.02%  0.00%   0 SAA Event Proces
104           0         1          0  0.00%  0.00%  0.00%   0 VPDN Scal
105       60864  16431137          3  0.00%  0.00%  0.00%   0 trunk conditioni
106           0         1          0  0.00%  0.00%  0.00%   0 trunk conditioni
108      190748   9746448         19  0.00%  0.00%  0.00%   0 Net Input
109      155028   3290773         47  0.00%  0.00%  0.00%   0 Compute load avg
110     3366928    283081      11893  0.00%  0.00%  0.00%   0 Per-minute Jobs
111        2856    137133         20  0.00%  0.00%  0.00%   0 CC-API_VCM
112     1238408 163822020          7  0.00%  0.00%  0.00%   0 CCPROXY_CT
115           0         2          0  0.00%  0.00%  0.00%   0 IP Flow Backgrou
117          40       223        179  0.00%  0.00%  0.00%   0 TCP Listener
118        8396    509053         16  0.00%  0.00%  0.00%   0 Kron Process
119      614248   6974492         88  0.00%  0.00%  0.00%   0 IP SNMP
120      154524   3451334         44  0.00%  0.00%  0.00%   0 PDU DISPATCHER
121     1439416   3452097        416  0.00%  0.00%  0.00%   0 SNMP ENGINE
122           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
123         380       389        976  0.00%  0.00%  0.00%   0 SNMP Traps
124     2784720 112449663         24  0.00%  0.02%  0.00%   0 NAT MIB Helper
125      197792  16968400         11  0.00%  0.00%  0.00%   0 NTP
126           0         1          0  0.00%  0.00%  0.00%   0 xcpa-driver
127      711364  48065369         14  0.00%  0.00%  0.00%   0 BGP Router
128     1371696  19810711         69  0.07%  0.01%  0.00%   0 BGP I/O
129     2527848   1098635       2300  0.00%  0.00%  0.00%   0 BGP Scanner
------------------ show process cpu history ------------------
Prithvi-II   09:36:02 AM Monday Mar 18 2013 IST
    7777777777777777777666666666677777888888888877777777776666
    3333000002222222222555556666633333888880000000000666665555
100
90                                   *****
80                                   **********     *****
70 ***********************************************************
60 ************************************************************
50 ************************************************************
40 ************************************************************
30 ************************************************************
20 ************************************************************
10 ************************************************************
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
    8788778787767776666666655555665655555556555555554554444454
    8700006800683007907435179594249298558400698598424142566638
100
90 *     *
80 ****  #** *
70 ####**#####*##*** *  *
60 #######################**** *#*******  *******             *
50 ######################################*########* *# ********
40 ############################################################
30 ############################################################
20 ############################################################
10 ############################################################
             0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
    6431233113222422223212332333233113222444444355533342233224534669999999
    0419341677964791622194329210526840857467010439877485732653735880698868
100        *******
90        **#*#*#**
80        *#######*
70                                                              **#########
60 *                                            **           *  **#########
50 *            *                        **    ***   *       * **##########
40 **       *   *                *      ****** ***** *      ** *###########
30 #**  **  *** ** * *   *********  ***********#****************###########
20 ##****************************** ******#########**********##############
10 ########################################################################
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
paolo bevilacqua
You have enabled a lot of features, NAT , QoS, flow esport, ACL just to name a few. And handling traffic that can probably have burst of some hundreds of mbps, see drops.
So all in all CPU utilization seems normal.
