Nexus 7000: How do I remove interfaces from a port-channel when those interfaces no longer exist?
cschaus
I need to add interfaces to a production port-channel.  The problem is that I am at the 8 interface limit for the port-channel, and I have 6 interfaces assigned to the port-channel that were interfaces on blades that are no longer in the chassis.  I don't want to have to delete the Port-channel as it is my VPC peer-link.  is there anyway of removing these interfaces without deleting the port-channel interface or putting a card in those empty slots and then removing them?
N7K-02# sho port-channel summary interface po1
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
        M - Not in use. Min-links not met
Group Port-       Type     Protocol  Member Ports
      Channel
1     Po1(SU)     Eth      NONE      Eth1/1(D)    Eth1/2(P)    Eth4/1(r)
                                     Eth4/2(r)    Eth7/1(r)    Eth7/2(r)
                                     Eth9/1(r)    Eth9/2(r)
Leo Laohoo
Duplicate thread.
Go HERE.
