09-27-2022 07:16 AM
N7K-A %ARP-4-INVAL_IP: arp [4557] Received packet with invalid destination IP address (10.168.96.0) from 2c53.4a04.2118 on Vlan226
N7K-A %NETSTACK-5-INVALID_NOTIFY: netstack [4585] ip_is_addr_local_active:Failed to get IP API VRF (null)
N7K-A %AUTHPRIV-5-SYSTEM_MSG: admin : TTY=unknown ; PWD=/var/sysmgr/vsh ; USER=root ; COMMAND=/usr/bin/strings /proc/25435/environ - sudo
Recently, I found that this log appears frequently, how is this caused, and how can I solve it?
thank
Solved! Go to Solution.
09-28-2022 06:22 AM
Hello @cong bao ,
what is the IP address and subnet mask configured under SVI interface Vlan 226 ?
There may be an host with an incorrect shorter less specific subnet mask that believes 10.168.96.0 is a valid IP address ?
I mean a /23 or less speciific prefix lenght
Can you trace the MAC address in the CAM table ?
Hope to help
Giuseppe
09-27-2022 07:35 AM
- These bug reports could be related : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCta54935 , and https://bst.cloudapps.cisco.com/bugsearch/bug/CSCsw95903 . note however the original message contains : ...NETSTACK-5-INVALID_NOTIFY... , the 5 uses the same problem indication numbers as for syslog , meaning notice and informational = Probably not too important.
M.
09-28-2022 06:13 AM
However, he is still reporting the error ARP-4-INVAL_IP, and not only received an invalid IP address, but also received an invalid MAC address. I doubt whether there is a spoofing attack, or should I go to the terminal corresponding to this MAC to find the problem
09-28-2022 06:22 AM
Hello @cong bao ,
Hope to help
Giuseppe
